Temperature Gauge has gone nuts!
Old Nov 28, 2005 | 08:44 AM
caldeesnutss's Avatar
I just notice this happening this past week. My temperature gauge is up 75-80% hot close to overheating when im in stop and go traffic or just sittting at a steady idle after the car is warm, but when im driving at a steady constant or just driving in the city past 20mph my temperature gauge is a the normal temperature. (around 25-30% up from cold)
I checked the radiator fluid and both radiator and the reserve were both full. No leaks.
Any reccomendations????
154,000miles
Acura CL 3.0 1997
caldee
Old Nov 28, 2005 | 10:55 AM
shineynitelite's Avatar
NAWWWWSSSSSS
make sure both fans are turning on, from there change the thermostat
Old Nov 28, 2005 | 11:36 AM
sxsublime's Avatar
cl-:P
i had this same thing happen to me and the dealer said it was because of a air bubble in the coolant line, they got rid of it but they said if it happened again to just turn the a/c all the way up for about 3 minutes and it should return to normall, its basically just a false read. Still tho bring it to the dealer to get it checked
Old Nov 28, 2005 | 11:42 AM
NAWWWWSSSSSS
turning on the a/c just turns on both fans.... no shit its going to get cooler
Old Nov 28, 2005 | 12:46 PM
should i remove the radiator cap so the air bubble can bleed?
Old Nov 28, 2005 | 01:40 PM
sgurg's Avatar
3rd Gear
I had the same problem recently and had to replace my radiator...even though I had just replaced it less than 2 years ago.
Old Nov 28, 2005 | 02:00 PM
did you have a leak in the radiator?
Old Nov 28, 2005 | 02:16 PM
sgurg's Avatar
3rd Gear
nope, didn't have a leak
Old Nov 28, 2005 | 11:02 PM
wilp99's Avatar
i agree with shiney,,, fans or thermostat.
isnt it nice to own a honda.. all the complaints are simple shit like oooh my thermostat is stuck.. or my window regulator broke.. at 150k miles... go to the ford site and its why did my engine blow up. why is this car such a piece of shit and i only have 90k miles on it.
Old Nov 29, 2005 | 02:38 AM
NAWWWWSSSSSS
^^ lol
i love the svt contour forums 90% of the modded ones are blown up.. they lbow up from a 50 shot for gods sake.....
or they blow up by themself becuase if your flooring it and take a sharp right turn the 2.5 will starve itself of oil (bad pan design) and cash itself lol gotta love fords
Old Nov 29, 2005 | 09:02 PM
the verdict is thermostat went bad.
$45.00 thermostat from acura plus new radiator fluid.
always remember when you change your thermostat to change when the car is completly cold or else it radiator fluid will explode all over you.
Old Dec 18, 2005 | 11:12 PM
krazy99cl's Avatar
O.G.
i think the radiator cap gives you the warning..but hahah Lolz...did it explode on you? you can always use a thick big cloth when you twist it off. only for people who are desperate and need fluid in their system.
Old Dec 24, 2005 | 11:12 PM
Fenix85182's Avatar
BlAcura 2.2CL
$45? Wow.
If you know where it's located (usually on the backside of the motor on the block...though I'm not sure on a V6), it's like an $8 piece plus maybe the same for a bottle of anti-freeze.
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
02tljj
May 2, 2019 08:56 AM
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
