Stumped
Old Mar 12, 2011 | 09:06 PM
catalyst529's Avatar
Stumped
Car is stuck in park. I've changed the brake light switch, checked fuses. lights work, and i can use the shift lock to manually override. I've been checking forums for the past few days and trying everything i've found anybody know what i could do?
Old Mar 13, 2011 | 10:25 PM
Acura1997Cl's Avatar
Only other car i seen do something similar was a 1992 Honda Accord and the linkage was bad.
Old Mar 14, 2011 | 02:19 AM
SD02CL's Avatar
There's a solenoid that releases the shifter that is more than likely the problem. If you take off the console around the shifter, you'll see the mechanism below and slightly forward of where you insert the key to manually release the shifter.
Scribesoft
Home & Garden
30
May 3, 2006 12:25 PM
zeroday
Home & Garden
Aug 7, 2005 09:52 PM
BigPimp
Money & Investing
24
Apr 14, 2005 01:41 PM
