starting problems
Old Mar 9, 2007 | 07:13 PM
jwolfe18's Avatar
starting problems
Ive been noticing lately on starting the car, itll crank fine, right when I crank it, it idles shitty and will bog out if I dont give it gas within 4-5 seconds of starting, if I give it gas itll be find and run fine after that.
What would be the cause of this any help would be great as this problem is really annoying.
Thank
Jon
Virginia.
Old Mar 9, 2007 | 07:59 PM
Sleep_DEPRIVED_Sleeper's Avatar
Turtle Charged, Biotcch!!
battery, spark plugs & wires... my car had the same symptom and turned out the battery only has 89amp (orig. 460 cca)...
Old Mar 9, 2007 | 08:31 PM
jwolfe18's Avatar
I got a die hard gold battery, ngk wires, and ngk platinum plugs,
so im gonna rule those out.
Old Mar 10, 2007 | 01:00 PM
ekim121's Avatar
Air, Fuel, or Ignition...you've ruled out ignition, so start working on air and fuel.
Old Mar 10, 2007 | 01:51 PM
jwolfe18's Avatar
what do you recommend workin one for the air and the fuel.
The fuel and air filer were also just changed.
what else should I change or look at?
Old Mar 10, 2007 | 02:33 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Throttle position sensor, that's why when you give it gas it starts workin
Old Mar 11, 2007 | 12:47 AM
spiderman3098's Avatar
you mite also mite want to try a lil seafoam if something might be clogging the fuel system making a kink somewhere.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
