Starting Issue
Hates the passenger seat!
Starting Issue
I turn the key and the engine clicks. All the lights come on, but it won't turn over. Is this a starter issue or a battery issue? Thank you guys.
Boston's Mizz
Dude, the samething happened to me with my cl....i thought it was the battery, but it really was the alternator. It will work when you put in the new battery, but eventually(very soon) you will drain that battery....have the alternator checked.
Having similar problem with 98 CL. Acura dealrship checked battery, alternator & starter but have not found problem. This does not happen all the time. When it does, all dash lights come on, clicking noise like ahorting & then after several tries it will start. I have cleaned the battery cables. Wonder if somethin is loose, shorting, ???
i'm ugly...go away
i had the same problem on my bmw but it didn't even click once. so it was the key starter. my ignition was broken so i had it replaced :X but ur car is still new i think so u shouldn't have that problem
cycdaniel
12-17-2019 10:58 AM
