Starting Issue
Old Sep 22, 2005 | 02:58 PM
gls's Avatar
gls
Hates the passenger seat!
Starting Issue
I turn the key and the engine clicks. All the lights come on, but it won't turn over. Is this a starter issue or a battery issue? Thank you guys.
Old Sep 22, 2005 | 08:29 PM
kwelling12's Avatar
I had the same problem with my GMC and it was a loose battery cable. Could be different for you but you might wanna check it anyway.
Old Sep 23, 2005 | 09:02 AM
gls's Avatar
gls
I have determined that the 8 year old battery is the problem. I will pick up a new one and let you know.
Old Oct 12, 2005 | 01:49 PM
Boston's Mizz's Avatar
Boston's Mizz
Dude, the samething happened to me with my cl....i thought it was the battery, but it really was the alternator. It will work when you put in the new battery, but eventually(very soon) you will drain that battery....have the alternator checked.
Old Nov 4, 2005 | 03:58 PM
rel500's Avatar
i have a 99cl 78k. it turned out to be the battery terminals
Old Nov 4, 2005 | 04:02 PM
gls's Avatar
gls
I forgot to update this.
I got a new Delco battery and it starts like new. And only $92 CDN!!
Old Apr 14, 2006 | 12:12 PM
sprucha's Avatar
6th Gear
Having similar problem with 98 CL. Acura dealrship checked battery, alternator & starter but have not found problem. This does not happen all the time. When it does, all dash lights come on, clicking noise like ahorting & then after several tries it will start. I have cleaned the battery cables. Wonder if somethin is loose, shorting, ???
Old Apr 15, 2006 | 12:09 PM
XBaDgEerLX's Avatar
i'm ugly...go away
i had the same problem on my bmw but it didn't even click once. so it was the key starter. my ignition was broken so i had it replaced :X but ur car is still new i think so u shouldn't have that problem
cycdaniel
Dec 17, 2019 10:58 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
NSolace
Sep 3, 2015 08:14 PM
