Speedometer issue.....
Old Jul 6, 2011 | 05:08 PM
LexT's Avatar
Hello,
just started to have this issue, did my search on this board, just want to make sure if its the VSS or my cluster itself............
1- the speedometer works fine 20% of the time
2- the other 80% of the time it shoots up to 20mph and stays there seldom it will start working then drops back to 20mph
3- the cruise control works perfect with the speedometer not working, I can increase/decrease speed as well, this makes me believe my VSS is working.
- I have no check engine light and the car runs great, everthing works on the car as it should.
- my car is a 98' 5speed 2.3cl
thanks in advance for the input...........
Old Jul 7, 2011 | 10:13 AM
Project_CLean's Avatar
MMkay.
my vote: speedometer. went bad on my car too; you could even try cleaning out the connections first see if it helps.
Old Jul 7, 2011 | 06:14 PM
DaInFaMMuS1's Avatar
Sounds like you might have to replace the cluster. I wonder if there's a way to self test the cluster to see if thats the issue. What I do when I see that issue is drive the car with a scanner connected and see if the vss is sending a signal
Old Jul 7, 2011 | 06:25 PM
LexT's Avatar
I got no scanner,..... cruise control works great even with the speedometer not working.......
Old Jul 8, 2011 | 12:00 PM
MMkay.
if the cruise control works; im guessing the computer knows what speed your at;hence the vss working properly
Old Jul 11, 2011 | 05:18 PM
antonio3rd's Avatar
vtec kicked in yo
what about a bad speed sensor? that could do it ....
Old Jul 12, 2011 | 08:45 AM
MMkay.
^he said cruise control works...
cycdaniel
Dec 17, 2019 10:58 AM
pstomps
1G CL Tires, Wheels, & Suspension
Oct 18, 2015 07:48 PM
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:38 PM
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:36 PM
Sep 17, 2015 08:57 PM
