Searched- no can find- brake question
Old 09-03-2011 | 04:24 PM
Soulman's Avatar
Hi, new guy here, I have a 97 with the 3.0. Just going through the brakes and the rear lower slide pins (not sure about the terminology) were seized up. I was able to rehab them sufficiently to make them work OK, but I would really like to replace them (already ordered) and the bracket that they slide into. My question is, are the brackets available, or would I have to order the entire caliper? If available, where can I get them- part number (Honda or Acura) would be a really great thing to have Any advice greatly appreciated. Thanks, Dan.
Old 09-03-2011 | 07:36 PM
saiko_cl_duck's Avatar
I'm having a hard time understanding what you are referring to.
Check out acuraautomotiveparts.org
you should be able to use the diagram to figure out what your part numbers are.
Old 09-03-2011 | 10:05 PM
Soulman's Avatar
Hi, I'm referring to the piece in the second pic in this thread
https://acurazine.com/forums/1g-cl-problems-fixes-71/seized-rear-caliper-788768/
It's a bracket that contains the two slide pins, apparently a pretty common problem with these cars. The web site you linked to is no help at all. I'm unable to find anything there, not even a complete caliper (maybe I'm missing it?). The piece I need is shown here:
https://www.oemacuraparts.com/index....0BRAKE%20(DISK)
It's the U shaped bracket in the bottom right portion of the diagram. It doesn't have a number associated with it. Any ideas? Thank you, Dan.
Old 09-04-2011 | 10:49 PM
Eband27's Avatar
They should be sold seperatly.
But as long as the slide fine, you should be ok
Old 09-05-2011 | 09:01 PM
Soulman's Avatar
Well, they slide, but not as easily as I would like. I'm sure the inside is pitted just like the pin is. They work well enough for now, but I'd feel a lot better with new ones- one of the rubber seals is trashed also.
Old 09-06-2011 | 10:04 AM
http://acuraautomotiveparts.org/acur...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
Found it just fine.
The pins are cheap enough, though when mine started to seize up, I just went and replaced the whole caliper. Just look it up at Advance or Autozone, they're not that expensive.
Old 09-06-2011 | 11:08 AM
Soulman's Avatar
I have the pins ordered. The part I'm wondering about is the bracket that the pins slide into (on the rear left brake). The piece is shown in drawings (it's roughly U shaped), but without a number by it (at least not that I've seen). Any idea on that? Thanks, Dan.
Old 09-06-2011 | 10:52 PM
I don't see a number either, looks like its a sub-assembly from the caliper assembly, probably only available if you order the whole caliper assembly.
mada51589
05-03-2022 08:54 PM
pstomps
02-20-2017 03:29 AM
datadr
09-12-2015 09:12 PM
HOWELLiNC
09-10-2015 01:39 PM
Quick Reply: Searched- no can find- brake question
