Replace Speedometer difficulty
Old Jan 26, 2009 | 06:56 PM
apecrazy's Avatar
How hard is it to swap either a speedometer or an instrument cluster? Is it a simple swap or does it require special calibration?
I have a speedo that bounces around, and I already replaced the VSS. Took it to Acura to diagnose and they said it was the speedometer. I would rather replace it with a used one to save costs if I can.
Old Jan 26, 2009 | 07:14 PM
AznX TL's Avatar
where is....
its fairly easy. just a simple swap.
Old Jan 26, 2009 | 07:27 PM
TexasHonda's Avatar
You could pull your instrument cluster and have repaired by online shops that specialize in instrument repair. If you buy a used cluster, you'll need to file an amended mileage statement to have a clear record of vehicle mileage, consistent w/ your reported mileage from inspections.
good luck
Old Jan 27, 2009 | 12:55 AM
f22vtec's Avatar
yea its very easy but some how something got messed up in mine idk how but its like half ass workin. its easy though i just dont know what the hell went wrong with mine!
Old Jan 27, 2009 | 12:13 PM
apecrazy's Avatar
Thanks for the info. I can replace the speedo only from a difft cluster can't I? Or is the cluster all 1 part? That way I don't have to worry about the odo being different.
Old Jan 30, 2009 | 01:09 PM
iansanderson's Avatar
'99 2.3 CL
What year, trim is your CL? You can replace just the speedo and it is fairly inexpensive and simple with household tools. You basically seperate the gauge cluster cover from the main board, and remove the black trim. Then unscrew 3 or 4 screws, and the speedo and odometer lift right out. Only prob is your milage will be considerably off if you purchase a new one.
number "10" (example is a 98 3.0)
You could also find a cluster from a junkyard and just PnP it into your car.. or take the speedo out of it. BUT.. if you are doing a complete swap it has to be from the same trim to work correctly.. eg. 2.2, 2.3, 3.0 and year.
cycdaniel
Dec 17, 2019 10:58 AM
pstomps
1G CL Tires, Wheels, & Suspension
Oct 18, 2015 07:48 PM
BKSleeper
Oct 7, 2015 10:20 AM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
Sep 15, 2015 06:44 PM
