problem with window...and its not the regulator
Old Aug 1, 2007 | 04:21 PM
jumpmanbsktbll's Avatar
2.4 L iVtec
The other day, my window was a tad cracked and i slammed it kind of hard and i heard a bang. I tried putting it up or down but all i heard was the motor, and the window wasnt moving. It can slide up and down, but when i slide it up there is resistance. I took my door panel off and found a wire hanging off. I have no idea what it is for nor where it came from. It looks like it has to wrap around something and is a relay to put the window up and down. Anyone know anything about this? Is it part of the whole assembly? Would I be able to fix it?
Old Aug 1, 2007 | 10:23 PM
ZeroCL's Avatar
W WHIP.
Is it the cable from the window regulator? If so, you have to replace the whole thing.
Old Aug 2, 2007 | 12:19 PM
saiko_cl_duck's Avatar
umm, it IS the regulator.
Old Oct 1, 2007 | 02:17 AM
CL604's Avatar
8th Gear
Wow I habr the same problem and it happened to me today. Saiko you sure its the window regulator?
Old Oct 1, 2007 | 11:53 PM
yes, the regulator is the whole assembly- cable, motor, and slide in one piece.
Old Oct 6, 2007 | 10:15 AM
acuraplaya's Avatar
My window rolled down slowly but in the end, it kinda made some "rough" noise and it never came back up. All I can hear is a cable rolling and the motor but the window remains where it is. I had to pull the window up (could not pull it all the way up) to drive back. I am sure it is the regulator. Can I but a 97 2.2 cl regulator for my 98 3.0? It is for the passenger side.
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
