Passanger Window Screech!
Hey everyone im new here, ill post an intro in a bit :p
For the past year or so i've been going insane whenever i lower my passanger window, it makes a god awful screech, The black lining looks as if someone was trying to use a screwdriver to break into the car from the passanger side and ever since then its been seperated and its rubbing on that, only issue is that when i move the black rubber out the noise still echoes from that window. It really puts a hamper on things![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Any ideas, suggestions? A good set of earplugs?![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
EDIT: Can someone point me to the intro section? I can't seem to locate it lol sorry its late.
1 Post
ive got the same issue. spray some goo gone on both the inside and outside of the window and move it up and down a couple of times. wipe away the excess fluid and it should stop making the noise. what happened in my case was there was some crap on the rubber that was causing it to WREEEAAAAAAAAARRRRKKK and that cleaned it off.
Thanks mate ill try it when i get some time and energy.
Thanks for the welcome
Ill post pics up once i wash it...so hopefully within the next few months
Once i get these next set of upgrades in ill take some picture for sure though.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
You say it still screeches even when you move the rubber out of the way?
Is th noise coming from inside the door kind of?
All CL window regulators are crap and will go out several times throughout the life of the vehicle.
When it's ready to go out soon sometimes it will make a screeching grinding noise when you lower or raise the window.
xsilverhawkx
09-28-2015 06:51 PM
AcuraKidd
09-25-2015 11:18 PM
