P0171 code - 1997 CL 2.2 runnig out of options
Old Aug 20, 2012 | 04:54 PM
wood-man's Avatar
Need some help with check engine light showing P0171 code on a 1997 CL 2.2L manual trans
So far I have done the following but still have the code showing up:
  1. Changed front O2 sensor
  2. Replaced MAP sensor
  3. New EGR & cleaned ports/passage on intake
  4. New Fuel filter
The only notable symptom when driving is an intermittent loss of power usually in second gear while going up or down a hill, but not always. Car idles fine
I have cleared the code but it comes back on immediately after above issue is noticed.
Maybe it's the fuel pump starting to go out but from what I understand they're pretty reliable. Car has only 132k in millage. Also car has after market air intake which was on the car when I bought it 3 months ago. It seems to be connected properly and I don't see any loose or cracked vacuum lines.
Any ideas would be helpful.
Old Aug 20, 2012 | 06:28 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
definitely sounds like a fuel delivery problem
Old Aug 23, 2012 | 07:26 PM
pitbullLOVER's Avatar
user & abuser
check your fuel lines, if the fuel filter lines arnt tight they can leak once pressurized. was there a aftermarket fuel pressure regulator on before that got taken off and the old one put back on???? the regulator might be bad but i heard honda reg's are good.
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
mars
Sep 28, 2015 11:03 AM
