P0171 code - 1997 CL 2.2 runnig out of options
Need some help with check engine light showing P0171 code on a 1997 CL 2.2L manual trans
So far I have done the following but still have the code showing up:
I have cleared the code but it comes back on immediately after above issue is noticed.
Maybe it's the fuel pump starting to go out but from what I understand they're pretty reliable. Car has only 132k in millage. Also car has after market air intake which was on the car when I bought it 3 months ago. It seems to be connected properly and I don't see any loose or cracked vacuum lines.
Any ideas would be helpful.
- Changed front O2 sensor
- Replaced MAP sensor
- New EGR & cleaned ports/passage on intake
- New Fuel filter
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
definitely sounds like a fuel delivery problem
user & abuser
check your fuel lines, if the fuel filter lines arnt tight they can leak once pressurized. was there a aftermarket fuel pressure regulator on before that got taken off and the old one put back on???? the regulator might be bad but i heard honda reg's are good.
Jamus22
06-11-2023 10:08 AM
