Oil in Radiator
Old Mar 3, 2008 | 10:22 AM
peel_lip's Avatar
Angry Oil in Radiator
I recently had replaced the head gasket, timing belt, and water pump, but oil is still mixing in with coolant in the radiator which then leads to my 2.3 CL overheating. Is the only other possible scenario a crack in the engine?
Old Mar 3, 2008 | 02:44 PM
AznX TL's Avatar
where is....
did you flush the radiator to get the oil out when you had the work done?
Old Mar 3, 2008 | 02:45 PM
peel_lip's Avatar
a very thorough flush
Old Mar 11, 2008 | 08:34 PM
tron's Avatar
Did you send the head through a shop when you did the head gasket to check for cracks or warping? I think it could be a cracked head or worse a cracked block.
Old Mar 16, 2008 | 12:17 PM
Dan3952's Avatar
Was your engine block machined when you had the head gasket done?
Has the car even been over heated?
IBankMouse
Jun 13, 2020 12:53 PM
Thuneau
Oct 3, 2015 04:19 PM
jubikej
1G RDX Problems & Fixes
Sep 30, 2015 01:13 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
