Oil Leak...
Old Dec 8, 2006 | 11:29 PM
vtecCL's Avatar
Oil Leak...
Replaced The camshaft seal on the timing side of the engine, and also replaced the valve cover gasket, and seems as if im still losing a good amount of oil from the camshaft seal....fairly puzzling..is there any possibility that my cam shaft could be bent and each time its spinning its creating a small loop to dispense oil around the seal?
Old Dec 9, 2006 | 07:06 AM
TexasHonda's Avatar
Are you sure you inserted the seal to the correct depth and was it a tight fit? Was this an OEM seal? Is seal leaking from camshaft/seal or seal/engine block?
Shaft seals depend on tight tolerances to seal correctly. Not much could damage a camshaft unless you've removed and reinstalled valve train.
Was it leaking before you replaced the seal? This is why I don't believe in preventive maintenance on seals. Too easy to create the problem you're trying to prevent.
I would suggest to try a new OEM seal. Make sure the sealing surfaces are very clean and unscratched, particularly the rotating camshaft surface.
good luck
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Thuneau
Oct 3, 2015 04:19 PM
jubikej
1G RDX Problems & Fixes
Sep 30, 2015 01:13 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
