Oil Filter Change
Old Aug 28, 2006 | 05:25 PM
Lajit-CL's Avatar
Oil Filter Change
I rarely use the CL now so it been a hile since I changed the filter. Over the weekend I drove the car up my ramp to change the filter, though there had got to be an easier way other that pay some one to do it. Other than lifiting the car and reaching up does any one have any tricks to make it easier?
Old Aug 28, 2006 | 11:42 PM
teh CL's Avatar
can't get any easier than that...
lift, reach, turn..
Old Aug 29, 2006 | 12:10 AM
CLean 3.0's Avatar
CLeanest in its CLass
if its a 3.0 you dont even have to lift just crank the wheels to the left all the way and you can reach the filter and drian plug from the side of the car. thats how i do my oil change, i could go through the trouble of racking it up on a lift at work, but this way works just fine.
Old Aug 30, 2006 | 04:26 PM
UnPimPMYRyd3's Avatar
Livin' la vida CL
This has one been one of the easiest car to do oil & filter change. I, too, have a 3.0.
Old Aug 30, 2006 | 05:10 PM
Blenz's Avatar
Make sure you put the new filter on as tight as you can with your hands and put the plug back on pretty damn tight too or it will leak. My 2.2 takes about 5 Liters
Old Aug 30, 2006 | 09:09 PM
CLean 3.0's Avatar
dont overtighten the filter if you do then when the next oil change comes around the filter will be tough to remove. the correct way to tighten the oil filter is; thin film of oil on filter seal, spin on filter till seal touches block and starts feelin a bit snug, then turn filter BY HAND 1/4 turn more that should seal just fine and will be removable by hand when next service comes around. as far as the drain plug dont overtighten that either if you do you can strip the threads on the pan
Old Sep 5, 2006 | 01:34 AM
FULLRACE's Avatar
you mean quarts ? Mine takes 4.5 i add the rest of the .5 after 1500
Old Sep 5, 2006 | 05:02 AM
CL'er 1st & 2nd Gen's's Avatar
Acura loyal for 93mo/109k
Blenz is one of those
5 liters = 4.4 quarts
bungln
Feb 20, 2019 08:47 PM
VolkingTL
Sep 16, 2015 09:10 PM
ghuns
Sep 16, 2015 04:26 PM
datadr
Sep 12, 2015 09:12 PM
Aleax
Sep 11, 2015 11:31 AM
