Noises
Noises
Every time i turn on my car a buzzing noise comes from what seems like my front drivers side... i don't know what is causing it but it is embarrassing and annoying and i want to get rid of it.
Anyone have this same problem or have any ideas for a fix??
97 CL 2.2 w/ manual trans
This is ABS modulator pressurizing the accumulator. It should go off after 5-10 seconds unless you have an ABS problem, in which case the ABS light will come on. If no ABS light, you don't have a problem.
good luck
good luck
Did you find a fix for this?
My ABS light is on with the modulator buzzing as well. Should I go in to find out the error codes, or is there another way I can fix this?
Tevans, what ended up happening with yours? Thanks for the help on this older post.
'97 CL Auto
'97 CL Auto
Mine has done this for years, the dealer's suggested fix was $1000+labor to replace the modulator, I read somewhere it's the rubber o-rings inside the modulator, I've just lived with it. If your ABS light is coming on, it could also be a wheel speed sensor, I've replaced 3 of those already
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
