Noises
9th Gear
Noises
Every time i turn on my car a buzzing noise comes from what seems like my front drivers side... i don't know what is causing it but it is embarrassing and annoying and i want to get rid of it.
Anyone have this same problem or have any ideas for a fix??
97 CL 2.2 w/ manual trans
This is ABS modulator pressurizing the accumulator. It should go off after 5-10 seconds unless you have an ABS problem, in which case the ABS light will come on. If no ABS light, you don't have a problem.
good luck
good luck
Did you find a fix for this?
My ABS light is on with the modulator buzzing as well. Should I go in to find out the error codes, or is there another way I can fix this?
Tevans, what ended up happening with yours? Thanks for the help on this older post.
'97 CL Auto
'97 CL Auto
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Mine has done this for years, the dealer's suggested fix was $1000+labor to replace the modulator, I read somewhere it's the rubber o-rings inside the modulator, I've just lived with it. If your ABS light is coming on, it could also be a wheel speed sensor, I've replaced 3 of those already
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
