No Brake Lights, but can still sift out of park. Help!
Old 05-19-2011, 07:48 PM
neocastillo's Avatar
None of my break lights are coming on. I suspect it's the brake light switch, but here's the thing. I have replaced the bulbs, checked the brake/horn fuse with a meter. The odd thing is I can still sift from pack to drive, and this make me think its not the switch and its something else.
What might it be?
Old 05-19-2011, 08:47 PM
Your Girlfriend is in my
RemieGino14's Avatar
Might be your fuse, should check if the fuse is blown.
- RemieGino14 -
Old 05-19-2011, 09:45 PM
Yes but the horn wouldn't work if the fuse was blown, right?
Old 05-21-2011, 12:51 AM
Acura1997Cl's Avatar
it probably a bad ground
Old 05-26-2011, 01:15 PM
Are you talking about an over all electrical system ground or a bad ground for the switch?
Old 05-26-2011, 01:22 PM
rockstar143's Avatar
Received 19,926 Likes on 14,464 Posts
There is a push switch located on the brake...when you push it it slides open and makes contact turning on the brake light circuit. In older cars...it can go bad and get "stuck" to where you press the brake and the little needle doesn't OPEN and engage the juice. Check it...you'll see what I'm talking about...it's going to be a little push thing that you'll see touching somewhere up the brake pedal. Press brake with hand and push pin in and out and have someone tell you if it starts working.
Try greasing up the pin and unplug and replug it in to see if that works.
rockyboy
12-06-2022 02:29 PM
mada51589
05-03-2022 08:54 PM
Laoch
1G RL (1996-2004)
10-02-2015 03:27 PM
1Lieutenant
4G TL Problems & Fixes
09-10-2015 08:39 AM
Quick Reply: No Brake Lights, but can still sift out of park. Help!
