my CEL light came back on
Old May 30, 2010 | 06:56 PM
P0401's Avatar
it had the code p1259 and on here from a search i found out it means something with the Vtech but what is causing it, anyone know? Is it a sensor or what?
Old May 30, 2010 | 07:05 PM
P0401's Avatar
I thought I posted this in the problems and fixes section (guess I hit the back button one to many times before posting new thread) so if someone could please move it i would appreciate it. I also wanted to add that I checked the oil and the oil level is fine
Old May 30, 2010 | 07:36 PM
P0401's Avatar
Also, it seems to be running fine. the light came on when I got on it a little bit to go around someone
Old May 30, 2010 | 09:00 PM
asianspec's Avatar
does vtec engage? did you check your oil? check also for dents on the oil pan, it can cause limp mode for the car.
Old May 31, 2010 | 10:39 AM
P0401's Avatar
checked oil and its fine. Do not see any dents in the pan but its raining today so I didn't get all the way under it to look, just did a quick glance under it. I am guessing the Vtec isn't engaging but can't find a picture of exactly where the switch is at on the 3.0. I got the pictures from alldata of the things it says to look for so I guess when it stops raining I will check those things out and see if I can figure it out.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
NJALLDAY57
Oct 13, 2015 08:25 AM
ibGTV
Sep 28, 2015 03:40 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
