low compression
Old Nov 14, 2009 | 05:55 PM
jahnemann's Avatar
low compression
so i recently purchased my 2.2cl and im about to go on a cross country drive to see my parents for thanksgiving. (my first solo trip ever since im only 16) and from the vehicle check i found out a couple things. one that my right front c/v shaft (boot) is cracked. which im getting fixed asap. and two im running low compresion in two of my four cylinders.
cyl 1-130
cyl 2-125
cyl 3-122
cyl 4-120
is their a relitively cheap way to fix the compression issue?
thanks in advance!
Old Nov 14, 2009 | 10:48 PM
Polaris573's Avatar
1998 CL 3.0
Hate to be the bearer of bad news but I think the minimum value for compression is about 135 PSI. Compression is low in all four cylinders. There is no cheap or easy fix for that.
Old Nov 14, 2009 | 11:58 PM
Shadoh's Avatar
Just out of curiosity... How did you go about checking the compression? How many times did you crank it on each cylinder?
Go back and retest it, and right down the symptoms, Here is a good write up on how to preform a compression test, and tell what is the likley cause of your issue. I found it on super honda acura today
http://www./forum/f55/how-do-i-perfo...n-test-124194/
Read through that and it will tell you how to do the test and tell what your issue is at the same time Hope it helps man!!
Old Nov 16, 2009 | 03:07 PM
jahnemann's Avatar
.........fuck. well, thats a mood kill.
08KBP_VA
Oct 22, 2019 01:55 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
Rcelestino93
Sep 23, 2015 10:01 PM
STL TL-S
Sep 23, 2015 08:52 PM
