HID kit not complete?
I ordered a set of Raptor HID's from DDM tuning many people said worked for them.. i didnt get the wires to run it to the battery, was it supposed to come with it.. or did i need to order them. Let me know asap before the march 14th meet!
Thanks in advance.
CL in lawnmower status
no, not many HID kits that i've seen come with that relay kit stuff, you'd have to make that yourself if you wanted to. These kits nowadays are plug and play meaning they just attach to your stock headlight connectors and that's it. The wire goes from the stock connector to the ballast and from there to the bulb.
Some ppl say relay kits are good so that you can run a higher guage wire to the ballast(which draws a lot of power on startup) i've never run one myself, as it'd be one more thing to do, and all the ppl i've known with hid's just run it into their stock wiring like normal.
Didn't your hid kit come with a wiring diagram which probably explained most of this?
So hook those HID's up now!!!
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
try flipping the plugs around 180 degrees, I had to do that for my pnp kit, they worked the opposite way that they looked like they should.
Dang beat me to it. It's called reversing the polarity and should be the ticket. Hope you didn't pay to much for those. As I get the $60 kit from hidgate on ebay 1 year warranty and it comes with the digital harness if requested and relay kit if requested
1 Post
As far as I know the only HID kits that hook up to the battery are the Dual Beam ones like mine. (9007).
The CL (9006) obviously doesnt need to switch from high to low because there is a seperate bulb for highs
(Mid-Atlantic)
(Mid-Atlantic)
my hid kit hooks up to the battery
![Ninja](https://acurazine.com/forums/images/smilies/ninja.gif)
ok well i found out they gave me the ass wrong directions.. and the ones on the website are half accurate
but.. i got them working and they look damn good
+1 for ddm
glad to hear it![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
my instructions were pretty shitty too, they stole the instructions from another company and did a half assed job of trying to erase the bright red watermark![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
just figured it out on my own basically
No, i didnt use the instructions on here.. although, i should have looked.. i had them in my garage for like 3 days before i did a buttload of thinking
trying to figure out how they would work.. i did the same thing as you. HID's FTW.. kinda makes me want to try projos now though..
haha, just think of all the effort and money. and what you could buy instead of projos, that's why i haven't done it yet, i keep thinking that.
FWIW: i meant the instructions i got with my HID kit, i don't remember there being any instructions on here for plug and play kits, besides flipping the plugs around.
Cuz they are plug and play, it's not as complicated as it used to be
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
7th Gear
I think I found it,
Are these the ones?
http://www.ddmtuning.com/products/Ra...it-102-85.html
And which color looks good? 8000K?
Also, do you usually install these on the 9005 (inner grille) or 9006 (outer) bulbs ?
Are these the ones?
1 Post
Looks like a normal old HID kit to me.
As for Color. Its all by preference.
6000k is basically hyper white with a real small hint of blue.
8000k is still pretty white but has more blue
I wouldnt go any higher than 8000K because they start loosing output and start looking really fake when you get higher in color temperature.
Also. your low beams are the 9006 so that is where you would be putting these.
Unless for some odd reason you choose to get the high beams (9005) instead. or both. But You really wont need your brights when you get these.
Here are 8000K in my Xterra. They arent that blue in person but still have a nice tone to them
![](http://i251.photobucket.com/albums/gg293/swiftt5389/My%202002%20Nissan%20Xterra/IMG_6264.jpg)
![](http://i251.photobucket.com/albums/gg293/swiftt5389/My%202002%20Nissan%20Xterra/IMG_6262.jpg)
![](http://i251.photobucket.com/albums/gg293/swiftt5389/Some%20Wheeling/IMAGE_175.jpg)
![](http://i251.photobucket.com/albums/gg293/swiftt5389/Some%20Wheeling/IMAGE_177.jpg)
![](http://i251.photobucket.com/albums/gg293/swiftt5389/Some%20Wheeling/IMAG0082.jpg)
7th Gear
Thanks swiftt5389,
That's some crazy parking with the xterra!
Here in Canada we have the inside lights as DRL (daylight running lights), so they are on all the time (at lower voltage output I'm guessing) and also serve as high beams. So if I install the xenons in place of 9005 bulbs, when the DRL are on at lower voltage would that even make sense or would it be a problem?
just purchase ddm HID. installed. but it seem like one side is brighter than other. i tried to ask other opinions and they said the samething.
what do i have to do? do i need to adjust the beam or something? help plz
tman570
06-11-2019 07:56 AM
BoricuaTL
04-08-2016 01:08 PM
09-15-2015 06:44 PM
