Help! Transmission Problem
Old Jun 6, 2007 | 12:34 PM
husein_100's Avatar
Exclamation Help! Transmission Problem
Hey guys, I need help. The transmission is acting up, When shifting between all gears it seems to IDLE , The RPM will go up (as if i have it in neutral) 1-2seconds it will finally shift and the car will jump. I have to let go of the gas to let it shift, If i don't the RPM goes higher and it takes longer to shift. It does this with All gears, 1-2-3-4 I'm trying to see where the problem could be in the transmission.Please HELP!
Old Jun 6, 2007 | 12:36 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Our auto trannies are notorious for going bad, start saving your for a rebuild, usually the torque convertor or the gears go bad
Old Jun 6, 2007 | 12:49 PM
husein_100's Avatar
I'd like to add this happened after the accident, the car was hit in the front and driver side, Was going about 15km/h on impact. Bumper had to be replaced. But I dont know why the transmission was affected. Could it be something thats off?
Old Jun 6, 2007 | 12:57 PM
ZeroCL's Avatar
W WHIP.
Just pretend and put it under insurance. Say something occured from the accident.
Old Jun 6, 2007 | 01:01 PM
husein_100's Avatar
Tried, I have to pay 600$ to bring it down and then they will open it up and see if it was cause of the accident or not, worried I might bring it down and they say no and im out 600$. Cant afford a rebuild right now
Old Jun 6, 2007 | 02:06 PM
(Mid-Atlantic)
Could be an axle if you were hit from the side
Old Jun 6, 2007 | 05:45 PM
F23CL757's Avatar
Fo' SHizzle
Not sure if your credits right, I had financed my transmission. But you could always give it a shot, and 1 word of advice, STAY AWAY FROM AAMCO, there WAY over priced, ran me $1800 for my rebuild with a 2 year warantee. But when mine failed it was somethign to do with a hydrolic something, may be whats goin in yours, or it may be as small as the tranny computer. Possible fluid service needed aswell. Could be alot of things, best thing to do is get it checked no doubt.
Old Jun 6, 2007 | 08:29 PM
(Mid-Atlantic)
Stay the F away from aamco
Old Jun 6, 2007 | 11:02 PM
Iagent's Avatar
The problems with the CL trans seems like sensors and electronics.
When cold, mine falls out of gear when coming to a stop, and then slams back in. However, if the car is in D1 or D2, it never falls out of gear. This means not a torque converter, but something else electronic. It's my daughters car, so I have her warm it, and drive the first couple miles in D2 before switching to D3 or D4.
Old Jun 7, 2007 | 12:37 PM
husein_100's Avatar
I'm gonna go get it checked out today, Thanks for the advice guys!
Old Jun 7, 2007 | 04:44 PM
Sleep_DEPRIVED_Sleeper's Avatar
Turtle Charged, Biotcch!!
that's exactly what i was doing a while ago... but driving in D2 eats up a lot of gas so now i just go start the car when i woke up, lock it with a second key, go back inside and do my morning ritual (brush, clean... for 10-15 mins), come back out, car's all warmed up, no more slipping...
Old Jun 7, 2007 | 09:15 PM
(Mid-Atlantic)
Cold slippage is one of the first signs of tranny failure fyi
Old Jun 7, 2007 | 10:39 PM
i know that, getting ready to dump more money into the car...
Old Jun 10, 2007 | 04:50 PM
husein_100's Avatar
My check engine light is on, How do I check the code without the tool, I think there is a "paper clip" mehod. Does anyone know how to do it on a 98CL. Pics would help Thanks!
Old Jun 10, 2007 | 06:11 PM
saiko_cl_duck's Avatar
please see the noob guide, or the other thread you started.
mada51589
Jan 9, 2025 04:40 PM
pstomps
Feb 20, 2017 03:29 AM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
