Help with oil pump '98 3.0
Old Mar 27, 2014 | 01:45 PM
swabbie82's Avatar
Could sure use help with this; I am doing a rebuild on my 3.0 (just seals), pulled off the oil pump and cleaned it. Noticed a notch on one of the pump rotor flats that engage the crankshaft to turn the rotor. The flats on the crank do not have a notch, but are smooth.What is this notch for, and does it make a difference which way it goes on the crank? I'm thinking maybe allows oil to front seal for lubrication? Need to be sure so I dont put it in the wrong way (that's what SHE said) lol . . . . Sorry. Any input appreciated, as its been almost 2 years and I'm really ready to get my "VTEC-ROD" back on the streets to do some heartbreaking to the Cobalt SS and possibly Subaru WRX crowd! Thanks!!
Old Apr 13, 2014 | 01:27 PM
BAGII's Avatar
yeah, it does have to go on a certain way cause obviously that flat spot is what turns the oil pump. if I remember right, make sure the crank is at TDC on cyl#1, and then I think the notched part is up while the flat spot is down.
BAGII's Avatar
Pictures to refresh my memory would be helpful.
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Jboat
Sep 30, 2015 10:58 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
