Mutliple codes after replacing thermostat
Old Mar 2, 2014 | 05:08 PM
sack25's Avatar
3rd Gear
Brand new member here!
My 1999 CL was not heating up, so I replaced the thermostat. Now it heats up fine, but it started running rough the next day and popped multiple codes (P0300, P0302, P0305, P1399). I do have 360,000 miles (hooray!) but I can't help believe that something I did caused the problem. Is it possible a poor connection on one of the wiring harness/ connectors could cause this problem? I had to disconnect 3 or 4 and I did spill a little coolant.
Old Mar 23, 2014 | 08:47 PM
sack25's Avatar
3rd Gear
New Discovery!
I checked my fuel pressure and it was at 48 psi, but did not drop when I reconnected my Pressure Reg vacuum hose. Took off the top of the intake manifold to get at the Press Reg, and noticed oil in the manifold. Took off the distributor cap and noticed oil in there too! But, I previously checked the compression and all cylinders were 170-185 psi and no leak down! Could it be as simple as a PCV Valve?
Old Apr 13, 2014 | 01:32 PM
BAGII's Avatar
Oil in the intake manifold is fairly common and not a huge concern. Oil in the distributor cap probably need to replace a seal. 48 psi for fuel pressure is pretty high. you could have a bad fuel pressure regulator, that's probably what I would replace first. but still, you have misfire codes, so I would inspect spark plugs closely, and check your EGR valve and passages for clogging. If EGR is stuck open, it will cause engine to run rough or even stall a lot of times.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
ibGTV
Sep 28, 2015 03:40 AM
Bahamanurse1
Sep 10, 2015 10:05 PM
NSolace
Sep 3, 2015 08:02 PM
