Getting locked in park
Old Sep 25, 2006 | 12:35 AM
datafstudblu's Avatar
a long time ago my 99 cl would get stuck in park and it would take me like 5 times to try and get it out then it went away. and now for the past 3 weeks it wont budge. so i have been having to put a screwdriver in that little whole next to the shifter and push that white lever down. and now all my break lights totally went out...it only works when i push the brake down all the way...any one have any ideas whats wrong....please help!
Old Sep 25, 2006 | 03:51 AM
CL'er 1st & 2nd Gen's's Avatar
Acura loyal for 93mo/109k
Brake sensor going bad? That would explain the brake lights and it's reluctance to get out of park.
Old Sep 25, 2006 | 07:26 AM
TexasHonda's Avatar
The brake light switch on the brake pedal is misadjusted, damaged, or failing. Switch should close as soon as brake pedal moves perhaps 1/4" downwards. If you look under the dash on the upper end of the brake pedal you'll see a spring-loaded switch contacting the brake pedal. As brake pedal moves down spring moves to close brake switch. It can be adjusted,...if you can reach the parts.
I hope your's is easy to access. On my 97 TL, it's just barely visible and no clue how to adjust or replace w/o major surgery. I had similar problem and a good dose of WD40 has cured so far.
good luck
Old Sep 25, 2006 | 12:41 PM
thank you. i appreciate it. ill try it out!
Old Oct 12, 2006 | 09:23 AM
gtflash's Avatar
I had this problem on my 98 3.0. The fuse for the brake light kept blowin out, just at random, and I was unable to shift out of park. However, the problem didn't like with brake nor shifter. The brake light and horn share the same fuse. There was a short in the wires for the horn, so everytime I tapped the horn, even if it didn't sound, the fuse would blow. I just tested the wires and disconnected the bad horn. Problem solved. Hope this helps.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
