Fuel Light Out??
Old Apr 14, 2010 | 07:17 PM
salogCL's Avatar
Fuel Light Out??
so im not sure if this is normal or just how the CL is. im running on empty. the gauge is below the E dash yet no light is on lol.
today i was pushing it tosee if it would go on.. did more than usual on a tank
is this normal?
Old Apr 14, 2010 | 08:35 PM
Miiike's Avatar
mine does the exact same thing, i've always wondered this as well
Old Apr 14, 2010 | 09:10 PM
salogCL's Avatar
lol like do i keep driving or what. lol its closer to 550 now. but i mean when i fill up im putting between 50-55 L and the tank hold 65
Old May 27, 2010 | 04:38 PM
salogCL's Avatar
so yea.. i ran out fuel like a fool. light never came on, so either bulb is burned out... or signal isnt being sent . shitty
Old May 27, 2010 | 07:00 PM
P0401's Avatar
I let mine get pretty low last week and my light never came on. I know it worked with the old gauges in it because i saw it come on when I first got the car so i took the gauges apart and switched the light just to be sure. I wish it was one of the lights that illuminated when you first turned the switch on like the rest of them
Old May 28, 2010 | 07:32 PM
salogCL's Avatar
yea .. not good to let it run out like i did.. lol send all the gunk from the bottom of tank right into the fuel filter.
Old Jun 11, 2010 | 10:37 AM
sporting's Avatar
Does the fuel light come on right before starting the car or not?
Mine does the same thing, I am thinking the light bulb is burnt?
Old Jun 11, 2010 | 11:09 AM
P0401's Avatar
No, I wish it was one of the ones that did illuminate to show the bulb is working but its not one of them
Old Jun 11, 2010 | 12:05 PM
sporting's Avatar
How do you know that it does not come on, is it in the manual? I am thinking of taking it apart and testing the bulb!
Old Jun 11, 2010 | 06:47 PM
Blazin Si's Avatar
Mine has never worked either. When the needle hits E, I have about another 40 miles before I need to fill up.
Old Jun 11, 2010 | 06:58 PM
salogCL's Avatar
lol its ghey
Old Jun 11, 2010 | 07:35 PM
Kyanite's Avatar
Stay Low Pro Kinfolk
Oh, you crazy Canadians/Rest of the World with your metric system... Lol.
Old Jun 11, 2010 | 07:57 PM
P0401's Avatar
Because I turn the switch to position 2 and it doesn't illuminate! when the tank gets down on E then it shines bright (at least it has since I changed the bulb). I may not have let it get low enough the first time but I changed it anyway to make sure
Old Jun 12, 2010 | 11:34 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
we have a 2 gallon reserve tank, chances are you're still hitting that, does your guage work otherwise, like on full, etc?
Old Jun 12, 2010 | 11:13 PM
salogCL's Avatar
gauge works fine... at E sometimes doesnt start quick.. second turnover starts, but the time it ran out,, i just wouldnt start, wierd thing is i managed to fit 55 L into it after, on a 65L tank ( wherd the 10 L go), so im thinking maybe something with the pump or pickup
Old Jun 14, 2010 | 09:49 PM
Mach30SiR's Avatar
Bagel Bomber
This has been a problem for me for a long time. I tried changing the bulb with another one in the cluster and that didn't fix the problem. I'm pretty sure its a signal issue from the quantity sensor. Ideas on a cheap fix? Other than that, i couldn't care less.
NBP_BALLER
Sep 23, 2015 08:18 PM
Sep 14, 2015 10:09 PM
PortlandRL
Sep 14, 2015 12:01 PM
Gary Matthews
2G CL Problems & Fixes
Sep 11, 2015 01:21 PM
NSolace
Sep 3, 2015 08:14 PM
