Fuel Light Out??
Fuel Light Out??
so im not sure if this is normal or just how the CL is. im running on empty. the gauge is below the E dash yet no light is on lol.
today i was pushing it tosee if it would go on.. did more than usual on a tank
is this normal?
is this normal?
I let mine get pretty low last week and my light never came on. I know it worked with the old gauges in it because i saw it come on when I first got the car so i took the gauges apart and switched the light just to be sure. I wish it was one of the lights that illuminated when you first turned the switch on like the rest of them
Because I turn the switch to position 2 and it doesn't illuminate! when the tank gets down on E then it shines bright (at least it has since I changed the bulb). I may not have let it get low enough the first time but I changed it anyway to make sure
gauge works fine... at E sometimes doesnt start quick.. second turnover starts, but the time it ran out,, i just wouldnt start, wierd thing is i managed to fit 55 L into it after, on a 65L tank ( wherd the 10 L go), so im thinking maybe something with the pump or pickup
This has been a problem for me for a long time. I tried changing the bulb with another one in the cluster and that didn't fix the problem. I'm pretty sure its a signal issue from the quantity sensor. Ideas on a cheap fix? Other than that, i couldn't care less.
NBP_BALLER
Sep 23, 2015 08:18 PM
