Electrical Issue
Old Sep 27, 2005 | 09:26 PM
DoubleSh0t's Avatar
Electrical Issue
I seem to be having an electrical issue with my 98 3.0L. Even since the rear LED spoiler was installed (in 99 or 00) the instrument panel lights will fade when the turn signals are on, especially if the brake lights are lit. The problem is more prominent if the climate control is turned off or if the fans are at a low setting. Sometimes even the headlamps will dim. I'm thinking it's a grounding issue with the spoiler, but could it be something more serious? As to why the problem was never fixed, the car belonged to my parents (I've purchased it from them) and they never got around to taking it back to the dealer. Anyone else get this before?
Old Oct 2, 2005 | 04:58 PM
ruin's Avatar
same thing on my car but they dim a little,if i put both my windows up at the sametime and if i step on the gas(while im puttingthe windows up) the get bright again. i dont know what it is ?maybe new battery?
Old Oct 3, 2005 | 09:34 AM
SwervinCL's Avatar
Nom Nom Nom Nom
The wiring for the leds are shorting something out. re wire the spoiler.
Old Oct 5, 2005 | 08:41 PM
Mach30SiR's Avatar
Bagel Bomber
its not his spoiler, i have the same exact problem....i feel your pain, i haven't been able to pin pointe the problem, nor have i looked though, lets see what the think tanks here can figure out.
Old Oct 23, 2005 | 11:56 AM
DoubleSh0t's Avatar
I'm going to check the spoiler either this weekend or hopefully by next weekend, see if it's a ground or a short. Hopefully that's all it is and it's not a deeper electrical issue (like the alternator).
Old Oct 23, 2005 | 07:40 PM
ayougo's Avatar
B A N N E D
Dam germans, sneaking into acura plants and wiring our cars
Old Oct 25, 2005 | 11:30 AM
SwervinCL's Avatar
Nom Nom Nom Nom
something is shorting out! rewire the spoiler.
Old Oct 26, 2005 | 04:00 AM
wilp99's Avatar
you have to use the wires for the 3rd brake light to power the spoiler. tap into those or just cut and direct connect them. it sounds like someone has the spoiler going directly to one brake light. prolly overloading the relay.
Old Oct 26, 2005 | 05:46 AM
ayougo's Avatar
B A N N E D
dam, you know like, everything about the dam cl. You could build one if someone gave you the parts it seems.
Old Nov 22, 2005 | 09:28 AM
Razor247's Avatar
I have the exact same problem. i checked it out where i work and my mechanic friend told me to do a simple test which may help... when u turn ur turn signals on, you will notice how the lights dim and come back as the signal lights up, now turn on our wiper blades while signaling. If the problem goes away, that means that the alternator is just not giving enough juice when the signal lights com one. My alternator works fine when i tested it on the diagnostics machine, but according to this test my alternator wasnt putting out enough power when the signals are on... no big deal because theres no harm done to the car
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
brandnewcolony
Sep 12, 2015 10:39 AM
Aug 30, 2015 02:39 PM
