EGR valve
Old Sep 12, 2006 | 10:57 PM
ougeta's Avatar
Saiyan Lv.3
EGR valve
So my check engine light just came on... so i took it to autozone for a check.
Turns out I need to change my egr valve.... anyone done this before, or know how hard it is to do..... also are there any out there that are cheap?
Old Sep 13, 2006 | 01:17 AM
asianspec's Avatar
there are people here that cleaned their EGR valve so i would look into that.
Old Sep 13, 2006 | 06:39 AM
saiko_cl_duck's Avatar
what you need is to call Acura customer service and have your VIN number handy. You have a 99 so you should still be covered under warranty by Acura. But that's all dependent on your mileage. If not, you're gonna need to have the EGR port cleaned out. That requires taking it out and drilling the carbon out, and also replace the lines going to it, those clog up also.
Old Sep 13, 2006 | 12:30 PM
TexasHonda's Avatar
What was code?
EGR valve rarely fails. If the code is insufficient EGR flow, the fault could be the EGR, but more likely is the distribution piping and manifold ports after the EGR. If code was insufficient EGR lift, the problem could be lack of vacuum to the valve, perhaps a broken or loose vacuum line. Lot's of possibilities. Diagnostics are called for unless you want to speed $150 for a new EGR w/ the possibility it won't fix your problem.
good luck
Old Sep 13, 2006 | 09:06 PM
ougeta's Avatar
Saiyan Lv.3
Thanks you guys, i am gonna try to clean it out and see where that takes me....
hopefully will not have to buy new egr
Old Sep 14, 2006 | 01:44 PM
AznX TL's Avatar
where is....
EGR is an extended warranty on acura 10yr/150,000
Old Sep 14, 2006 | 03:45 PM
Mach30SiR's Avatar
Bagel Bomber
wrong infomation.
Old Sep 14, 2006 | 03:47 PM
Mach30SiR's Avatar
Bagel Bomber
http://www.acura-cl.com/forums/showthread.php?t=174570
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Mike734
Dec 10, 2021 01:25 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
prbori
Sep 27, 2015 01:37 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
