DRL Problem
Old Jul 17, 2006 | 12:16 PM
Dicorp's Avatar
Unhappy DRL Problem
I'm having a problem with my lights. The DRL Light is on when I start the car, then comes off when I turn on the dash lighting and then the beams. It then starts to flash erratically along with the high beam indicator, with the high beams not working. I have no idea why its doing this. Thanks for any advice in advance.
Old Jul 17, 2006 | 07:35 PM
TexasHonda's Avatar
You should check the connection to the DRL control unit, usually under the dash.
If that's OK, I would suspect either your headlight relay is weak or your steering column switch.
You will need a shop manual w/ circuit diagram and location diagram to locate the DRL relay and headlight relay.
good luck
Old Jul 18, 2006 | 07:46 AM
Dicorp's Avatar
good luck
Where could I obtain such a manual and what exactly would I be looking for? What does this relay look like?
thanks
Old Jul 18, 2006 | 11:45 AM
TexasHonda's Avatar
Manual is available from helminc.com, and other internet sources. Try a google search for "Acura Shop Manual".
Headligh telay is probably located in the underhood fuse box. The DRL is usually in the pax cabin underneath the dash. I don't have a manual for your model.
good luck
Old Jul 18, 2006 | 09:13 PM
SupraManAG's Avatar
One custom CL
i have the Helm electrical manual
let me know if u need any of the pages
Old Jul 19, 2006 | 08:04 AM
Dicorp's Avatar
Supra
Thanks, I will let you know if i need anything
But Im thinking that the fuses cud be blown...I think I'll replace those first before i start removing the dash and all. If its that serious I might consider taking it to a shop...Im no good with electronics.
Old Jul 19, 2006 | 10:08 PM
Dicorp's Avatar
Well after checking the fuses, they all turned out to be fine, i've narrowed it down to the DRL relay and the Headlight (lighting) relay. Also upon a closer examination, i figured out it was my high beams that wont come on, the DRL's are fine. Now im confused wether i should replace the DRL relay (150$) or the Lighting Relay(40$). The dealer told me to book and appointment so they can charge me 45$ for diagnostics The only hint I have is that after removing the Lights Relay, Low Beams wont come on either. Any Ideas guys?
Thanx in advance.
Old Jul 20, 2006 | 06:28 AM
TexasHonda's Avatar
The headlight relay enables both Hi and Lo beams. so removing should disable both hi and lo headlights.
Check elsewhere for the headlight relay. I suspect it will be available from aftermarket sources at much lower cost. Make sure the connection to the DRL relay is sound and not damaged.
Check used parts outlets for a DRL control unit. I like car-part.com which allows you to identify parts near your home.
good luck
Old Jul 20, 2006 | 08:35 AM
Dicorp's Avatar
Well I replaced the head light relay 2day, but still no luck ...at this point i think my high beams bulbs might be burnt out cuz of the relay malfunctioning.Since this was a recurring problem, they did work every now and then...this is my reasoning for assuming the bulbs are burnt. This proving to be a headache
Old Jul 20, 2006 | 10:59 AM
agranado's Avatar
how handsome I am
^^what's even more of a headache is that you have to take it to the dealer for a 45$ diagnostic
good luck.. hope your pockets are deep
Old Jul 20, 2006 | 11:39 AM
Dicorp's Avatar
They arent deep at all..but i still prefer doing trial and error myself rather than paying some1 else fiddle with my car. Ima stop at the bulbs, if that dont work..f-it...i can deal with no hi beams.
Old Jul 21, 2006 | 07:24 AM
Dicorp's Avatar
Well I Tried changing the buls yesterday, after the high beams had a glimpse of life by one of them comin on...put in the bulb....nothing....both refuse to come on...this is amazingly stupid. Its pretty much back to usual behaviour...flashing dash indicators, high beam working every now and then. Im completly confused
Old Jul 26, 2006 | 12:18 AM
ekryski's Avatar
I'm having a similar problem. My leftt daytime running light and highbeam erractically comes on and off at random times. I can't figure it out but I haven't tried too hard. I will let you know if I figure out what is wrong.
Old Jul 26, 2006 | 07:31 AM
Dicorp's Avatar
I appreciate the help..I'm actually waiting for a DRL relay to get mailed to me from ebay, I found a decent deal for bout 50$. Hopefully it will help Once It gets here and I install it, I will post wheter it worked or not.
Old Jul 27, 2006 | 07:19 PM
Indeep's Avatar
DRL relays get cracked solder joints. Just take the circuit board out of the case and resolder any joints that look like they are cracked.
Old Aug 1, 2006 | 07:07 PM
Dicorp's Avatar
Smile
Received the DRL relay I ordered from Ebay a while ago and it fixed the problem. Too bad I bought a new headlight relay, waste of 40$ Oh Well At least i have properly working lights now.
Old Aug 1, 2006 | 10:37 PM
UnPimPMYRyd3's Avatar
Livin' la vida CL
I wouldn't say its a waste. You're still ahead since you can either sell the relay or keep it for when it goes out. You're ahead compared to if you would have gone to the dealer.
JMTCW,
UPMR
SidhuSaaB
May 30, 2020 12:40 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
