Driver Side marker light..how to...99 cl
to replace the bulb in the "drivers side marker light" do i simply just unscrew the bolt on the one side of the main piece??
than just pull out (or pop out) the entire light piece to get to the bulb??
or is there something else to it??
and if so should i replace both sides at the same time even if one side is out?
thanx
1999 Acura cl 2.3
thanx
1999 Acura cl 2.3
I assume you mean the lower corners? If so, check out this guide
https://acurazine.com/forums/1g-cl-diy-faq-74/clear-corner-install-470705/
For the top ones, you just turn the corner bulb and pop it out
ok..managed to take it out and replace it..actualy im going to return thebulbs i bought cause the old one is working fine..probably just wasnt inserted properly or got loose..now all is good BUT the little square bracket the things screws into came off and now my light piece is loose..is there a way to tighten that in??or just get a new square bracket from home depot or something??
thanx 4 replies... i got it sorted out..luckily my mechanic friend was in my area and stopped by and fixed it...nice and secure now and also got my 3rd brake light changed..and un-sqeeked my door and window.. cheers all
Oct 21, 2015 11:38 PM
sockr1
Oct 1, 2015 01:31 AM
