Couple of issues
Old Dec 29, 2007 | 01:50 AM
themadmarmoset's Avatar
JAPCARLUVR
Couple of issues
First off, on occasion my 99 will start off with a rough idle, gas it up and it's good to go.
Secondly, when I open the throttle up from about 25 mph I get a hesitation almost like a stall @ 5,000 rpm but it quickly regains composure. I want to fix this ASAP.
Old Dec 29, 2007 | 03:03 AM
asianspec's Avatar
say goodbye to the tranny
Old Dec 29, 2007 | 03:10 AM
Nautsiju's Avatar
what kind of engine/transmission?
Old Dec 29, 2007 | 10:43 AM
JAPCARLUVR
Auotmatic tranny, 3.0
Old Jan 4, 2008 | 06:54 PM
whittles's Avatar
sounds like a fule filter issue
Old Jan 10, 2008 | 12:01 AM
JAPCARLUVR
It doesn't seem to me to be a fuel filter issue as this only happens around the same RPM's. There is a significant loss of power, with what seems like a nitrous burst after it recovers. My guess is it is CPU related, any other thoughts?
Old Jan 10, 2008 | 12:25 PM
TexasHonda's Avatar
Hesitation can be caused by partial EGR manifold ports blockage. Too much EG into some cylinders and not enough in others leads to lean miss and hesitation. Idle should not be affected by EGR unless the EGR valve itself is leaking.
Make sure plugs are in good shape. Check and replace air filter if necessary.
good luck
Old Jan 12, 2008 | 12:11 AM
stevebri's Avatar
I had that hesitation issue as well, but only when I was accelerating. It turned out to be a bad trans that had to be rebuilt
cycdaniel
Dec 17, 2019 10:58 AM
snorf
Nov 4, 2019 06:44 AM
01CLOwner
Oct 9, 2015 01:07 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
NSolace
Sep 3, 2015 08:14 PM
