Coolant system?
Old Jan 20, 2010 | 07:24 AM
illadel.cl's Avatar
Question Coolant system?
Aight did a rad..(98 2.3) filled w/ heat cranked... But didn't bleed system.. Now after findin out about bleed valve I went to bleed it first thing in the morn a little fluid came out and stopped I tryed takin rad cap off to get a constent stream but nuthin?? Any insight would be great and helpful jus want to make sure there's no air in system???
Old Jan 20, 2010 | 08:33 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Try running the car with the cap off, it should bubble if there is air in the system
Old Jan 20, 2010 | 09:31 AM
illadel.cl's Avatar
Yea tryd that.. No fluid... Comes out?? I jus got the thermostat done a week ago?
Old Jan 20, 2010 | 09:42 AM
illadel.cl's Avatar
The thermostat was done w/ the timing belt & water pump.. Soo it's circulating... Top hose gets hot first.. No high temp on gauge.. Jus want to make sure no air in system. When I ran the car w/ cap off (cold) mad fluid came out the top of rad? And it wasent warm yet?
Old Jan 20, 2010 | 11:44 AM
Fenix85182's Avatar
BlAcura 2.2CL
The coolant system is under pressure. It's not surprising that even when cold that liquid can run out. Your best bet is to start the car with the radiator cap off and bleed the system by adding fluid and by adjusting the bleeder valve. On my '97 2.2 it is located behind the head near cylinder 4. It literally is a bleeder valve, much like you see on you brake system.
Old Jan 20, 2010 | 01:06 PM
illadel.cl's Avatar
If know where the valve is.. Sooo.. Ur sayin crack the valve and pour fluid? Even if it's excess and over flows? And allow it to flow thru the bleeder then seal.. Correct?
Old Jan 20, 2010 | 03:31 PM
Eband27's Avatar
yea, it doesn't rly matter if it leaks out a bit.. just poor some water on the coolant in your driveway, and it become neutral.
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
SiClone
Oct 1, 2015 10:22 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
