Clutch Noise
Old 06-30-2006, 08:10 AM
Dicorp's Avatar
Clutch Noise
Whenever I depress my clutch, it makes squeaking noise, sounds like a spring or something. Anyone know what this might be? This is a 97 2.2 CL, 155K KMS.
Old 06-30-2006, 07:08 PM
TexasHonda's Avatar
There's a bearing called the the release bearing or throw-out bearing. If the grease drys out, it will begin to squeal when you depress the clutch. Bearing probably only needs to be cleaned and repacked w/ grease.
However,...accessing the bearing requires removing the transmission :<(
Sometimes the noise will resolve itself, if a little grease melts and coats the bearings.
good luck
MrHeeltoe
20
02-23-2023 01:54 PM
SexyRL
4G TL Problems & Fixes
08-19-2016 10:03 PM
xsilverhawkx
10-05-2015 11:00 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Clutch Noise
