Cigarette Lighter Not Working
Old Dec 26, 2008 | 09:16 AM
MikeSwing's Avatar
Hey guys. My cigarette lighter doesn't work anymore at all. I can push it in but it doesn't get hot and I can't get power out of it. What needs to be replaced and can I do this at home? Thanks in advance people.
Old Dec 26, 2008 | 11:04 AM
Yurhomieblaze's Avatar
cool breeze
it's a sign, your car wants you to quit smoking
check your fuses first
Old Dec 27, 2008 | 12:53 PM
MikeSwing's Avatar
The fuse is fine. Not smoking. Need to charge up the Blackberry.
Old Dec 27, 2008 | 01:25 PM
cool breeze
good for not smoking
i'd pulled the dash apart to get to it and check if there's power to the rear of lighter(or whereever the lighter connects to power) if theres power, the sockets bad, if not then theres a short somewhere
you'll want a voltmeter to check for power
Old Jan 5, 2009 | 10:14 PM
mikerider's Avatar
This happened to me and frustrated the snot out of me. I looked everywhere for the problem. Finally I got fed up and let a mechanic (backyard, but very experienced) take a look at it - this after driving the car with the lighter out of it for 2 years.
When he took the female end out of the console he found a solder had melted and the wire was no longer connected. He took it home soldered it, and put it back the next day. Problem solved.
BTW this happened after I used a compressor to fill up a slow leaking tire. I guess the constant drain melted the solder.
Hope this helps!
Old Jun 11, 2011 | 01:24 PM
MikeSwing's Avatar
Mine still doesn't work. Fuse is fine so it must be the back of the lighter. I'm gonna have someone look at it.
Old Jun 18, 2011 | 11:56 AM
Eband27's Avatar
The inside of the "socket" might have corrosion, which prevents the current from flowing. I think our lighter socket just pops out, take it out, and look at the connections in the back.
Old Jun 18, 2011 | 01:07 PM
MikeSwing's Avatar
How to 'Pop' it out?
How do you 'pop' it out. I think I'm gonna break it. I don't see any clamps holding it in. Thanks again for the help.
Old Jun 20, 2011 | 08:34 AM
Project_CLean's Avatar
MMkay.
what year cl do you have? my 97 screwed out if i remember correctly. also the harness on these sometimes go bad.. the actual connector burns out over time.. happened to me.easy fix.
Old Jun 20, 2011 | 09:02 AM
MikeSwing's Avatar
It screws out? I have a 97 too. Does it screw out from the inside or outside of the dash piece? If the actual connector goes out, did you just get another one from Acura?
Old Jun 20, 2011 | 10:00 AM
MMkay.
you have to remove the trim ring, and ashtray and disconnect everything from behind unless you want to take out your radio which will be a looott easier. trust me. then just pull out
Old Jun 21, 2011 | 03:10 PM
P0401's Avatar
there is a sleeve that fits over the element you can see that screws on to the cover. You have to hole the part where the cigarette lighter fits in and turn the sleeve on the back to take it apart
Old Jun 21, 2011 | 08:37 PM
97'CL2.2's Avatar
dont wana hijack this thread but my cig lighter gets power normally however the actual lighter wont stay pushed in..i have to hold it in until it gets hot...anyone else experience this problem?
mada51589
Jan 9, 2025 04:40 PM
acurajj
Sep 19, 2015 03:47 PM
Sep 14, 2015 10:09 PM
kuzdu
Sep 10, 2015 08:42 PM
ahsm
Sep 9, 2015 08:35 AM
