Check engine/Misfire on Cylinder #2
Old Nov 14, 2008 | 02:37 PM
j-dizzleCL's Avatar
9th Gear
so, i have replaced the dizzy cap,rotor,plug wires and plug(ngk iridium's) but i still have a misfire on #2. sometimes it hesitates or stumbles around 2k rpm. could this be a coil issue or something else? i have a CEL and all i get is misfire on #2,nothing else. i tried to replace the fuel filter and will never try that again,the worst engineering i have ever seen. i dont think the o2 sensors would cause this but i could be wrong
thanks
jason
Old Nov 15, 2008 | 06:52 PM
TexasHonda's Avatar
Misfire on No1 (P0302?) is a miss on cylinder no. 2. The issue doen't have to be electrical. It could be a faulty injector or intake manifold air leak. For ignition check for a cracked distributor rotor, distributor tower crack, bad #2 wire, bad #2 plug.
good luck
Old Nov 17, 2008 | 03:35 PM
j-dizzleCL's Avatar
9th Gear
it was a bad ignition coil. the old coil was bad,looked original hitachi. replaced it today and everything works fine. thanks
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
STL TL-S
Sep 23, 2015 08:52 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
