Car wont start
Old Aug 7, 2005 | 01:53 AM
Cokio's Avatar
"Blitherin Blather Skyte"
Car wont start
when i turn the key the friggin car wont start up. everything else comes on, the lights, sound system, dashboard, etc. i hear the clicking sound but the car just wont start? what should i do, Dr. Phil???
Old Aug 7, 2005 | 04:52 AM
hondasir's Avatar
yes SiR
probly the starter?. note: recall for ignition switch from acura, could be that too?.
Old Aug 7, 2005 | 10:47 AM
starboy2nv's Avatar
First EVER K24 Turbo CL
tap ur starter then start
Old Aug 11, 2005 | 05:15 PM
krazy99cl's Avatar
O.G.
its your starter for sure....but for now you can get a wooden pole and hit it....starter is slipping
Old Aug 12, 2005 | 04:39 PM
legendaryCL98's Avatar
'07 November = STI
it could be your battery.. it might not have enough juice to start up your car.. but enough to get your electronics working..
Old Aug 12, 2005 | 11:36 PM
Chinisimo's Avatar
tap the starter 1st then the battery.
Old Aug 24, 2005 | 08:41 PM
Acura3.0CL's Avatar
DamnThisHobby'sExpensive!
what do you mean by tapping the starter??
Old Aug 31, 2005 | 01:20 PM
SwervinCL's Avatar
Nom Nom Nom Nom
Just take your starter out and take it to autozone and have it tested, they do it for free!
Old Aug 31, 2005 | 01:26 PM
SwervinCL's Avatar
Nom Nom Nom Nom
Old Sep 2, 2005 | 11:02 PM
Bigpimpin18's Avatar
Soon to be H22 turbo!
wut they mean is take like a screwdriver handle and hit ur starter (fairly hard) while someone is trying to start ur car, it means that ur solenoid could be dirty, or if that doesn't work, replace ur starter.
Old Nov 17, 2005 | 02:36 PM
megaman81's Avatar
I am having a similar problem...when i turn my key, it just makes clicking sound. When i keep trying to start my car, after couple tries it starts right up. Sometimes it feels like it works right away when i turn my key slowly. Im thinking its the ignition switch problem.
Anyone else encountered this kinda problem and it turned out to be starter??
thanks
mc
Old Nov 17, 2005 | 02:39 PM
'07 November = STI
thanks
mc
clicking usually means its your battery.. check your cables for corrosion.. and wipe it off clean.. and also if u didnt change your battery for a REALLY long time.. u should do that
Old Nov 20, 2005 | 06:50 PM
megaman81's Avatar
I cleaned off my battery terminals and and installed new postive terminal. The battery voltage when car off is 12.56v, and about 14.36v when car on...I am thinking its the starter? How hard is it to remove the starter from the 2.2cl? I am thinking about removing it and taking it to pepboys to get it tested. It just clicks and it starts sometimes and sometimes it just clicks and i have to turn it couple times and it will start up.
Old Nov 21, 2005 | 01:22 PM
'07 November = STI
i never removed a starter before.. so i wouldnt know how hard it is.. maybe u could search this forum and find your answer..
IMO ... it shouldnt be too hard to take off and put back on
Old Nov 24, 2005 | 08:57 PM
bostonroads's Avatar
Who the F*** is Chucky?
i believe it works without something trying to start the car at the same time...its usually not a good idea to have someone fiddling under the hood when you start the car up..you never know what could happen if something catches you
Old Dec 19, 2005 | 05:28 AM
krazy99cl's Avatar
O.G.
you tap it like you tap a%$...haha jk....hmm almost as if you are hitting a nail into a wall(drywall) not too hard nor too soft...
Old Jan 5, 2006 | 02:03 AM
subbuzz's Avatar
07 tl-s in
same thing happened to me today! so what was it?
Old Jan 7, 2006 | 07:06 AM
subbuzz's Avatar
07 tl-s in
answered my own ? it was the starter $250 installed
Old Jan 7, 2006 | 07:26 PM
SwervinCL's Avatar
Nom Nom Nom Nom
You got raped on that one!
Do you have a 3.0 or a 2.3?
Old Jan 10, 2006 | 01:10 AM
subbuzz's Avatar
07 tl-s in
3.0
Old Jul 5, 2009 | 12:09 PM
69nmyway's Avatar
Talking It's the starter!
YUP, It's the starter on mine. I went out and tapped the starter and it started up but you can tell the starter is dragging. Now off to the auto store to buy one!!! Thanks guys, thank god for the internet!!! NO MORE being RAPPED by the repair shop just for a diagnosis!!!
Old Jul 5, 2009 | 10:14 PM
Master Bill Flex's Avatar
if only cars came with a pull start...
saberlove
Mar 11, 2021 09:29 AM
Feb 25, 2020 09:57 AM
bearingman07936
Jan 7, 2016 03:22 PM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
