Car is starting rough and is bogging down
Old Dec 12, 2014 | 07:25 PM
ohferkyeah's Avatar
Sometime my car starts real rough like it's not getting gas and then when it's driving if I give 3/4+ throttle, the car kind of lags (you can actually feel it pull back) and then it surges forward fast as if I've just come off the clutch. It's does not do it all the time can anyone give me some suggestions on what I should look at
Old Apr 25, 2015 | 10:51 PM
demebaker's Avatar
3rd Gear
Check your iac valve
Old Apr 26, 2015 | 07:53 PM
musiclevelz5's Avatar
iac valve usually only affects idle control, not when your above 5-10% throttle.
When is the last time the car had a tuneup? NGK plugs, NGK wires, new cap/rotor?
Do you know how to check your timing? Make sure the marks line up when at TDC.
Also get a fuel pressure gauge. You could have low fuel pressure causing a loss of power sometimes.
Old Apr 26, 2015 | 07:56 PM
demebaker's Avatar
3rd Gear
I changed the distrubiter put a brand new one in the car is running now thanks
Feb 25, 2020 09:57 AM
bearingman07936
Jan 7, 2016 03:22 PM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:14 PM
