Car Overheats - Speedometer stopped working!
Old Nov 7, 2006 | 10:00 AM
sandy10872's Avatar
Question Car Overheats - Speedometer stopped working!
HELP!!!
My car started to overheat yesterday, there was a leak in my radiator hose. After 3 miles of driving, my thermometer went up....so I turned around to go home and all of a sudden my speedometer went crazy and then went to zero! BUT I WAS STILL DRIVING. Do you think my circuits just went crazy from overheating? I haven't driven it as it is being worked on. I am going for a diagnostics later, but thought someone might be able to point me in the right direction!
Thanks!!!
Sandy
Old Nov 7, 2006 | 05:41 PM
Sleep_DEPRIVED_Sleeper's Avatar
Turtle Charged, Biotcch!!
weird, the same thing just happened to me this morning, although only the thermometer went beserk... when i idled at a red light, the needle rises quickly to the red mark...i was SCARED!!!
I drove to a shop immediately and got it fixed... turned out there's a leak on the radiator hose and radiator cap... also the thermostat needed to be replaced so i did that...
Overall, 80 bucks for everything: hose leak, new rad cap, new thermostat, i also told them to put in the front & rear upper strutbar ... car drives like a champ now...
You should ask them to check the things that i mentioned...hope that helps....
Old Nov 11, 2006 | 03:25 PM
Nakamichi's Avatar
~[τΏτ]~
I could have been possible that the Vechicle Speed Sensor (VSS) or CounterShaft Speed Sensor was damaged during the leak. For a 97 3.0 CL the speed is measured by the VSS. Not sure about the 97 2.2 CL. 98-99 2.3 and 3.0 CL the VSS was removed and the Countershaft Speed Sensor measures the speed.
Bahamanurse1
Sep 10, 2015 10:05 PM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
dlknight
Sep 3, 2015 07:54 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
