A/C blowing hot air
Old 05-26-2008 | 07:28 PM
Mr.Felts's Avatar
3rd Gear
A/C blowing hot air
my 1999 acura 2.3 cl blows hot air when on. What can I do and how much would it cost?
Old 05-26-2008 | 07:29 PM
AznX TL's Avatar
where is....
maybe it needs freon recharge?
Old 05-27-2008 | 01:13 PM
TexasHonda's Avatar
Loss of cooling could be many things. Losing coolant is one of them. Others are; fuse blown on compressor, bad compressor relay, open compressor coil, etc.
You will need professional help to determine cause for no-cooling.
good luck
Old 05-27-2008 | 06:05 PM
Mr_Xclusive808's Avatar
When you turn your a/c on listen to make sure that the clutch on the a/c compressor is enguaging. If it does turn on then it's more then likely just low on freon (R134a). Get the R134a wit the guage so u can pressure test it & add freon to the system. Make sure if you do this yourself to do it through the low side a/c fitting
Old 05-27-2008 | 07:49 PM
saiko_cl_duck's Avatar
mine was doing the same thing. Best bet is to take it to a good shop and have them drain the system and do a vacuum check on it. Found out my pressure switch was bad, only cost about 90 bucks altogether.
Old 05-28-2008 | 08:07 PM
TexasHonda's Avatar
Good advice from Saiko. A Walmart recharge kit is asking for more problems; damaged compressor requiring extensive repair. If the system leaked down to no pressure, there is a leak that must be repaired.
good luck
Old 07-12-2008 | 06:49 PM
TrueNorth's Avatar
'97 2.2CL 5spd
I found many A/C re-charge complete kits that include the freon (R134a / R12) , gauges for application, and some form of a "stop-leak" style of fluid that says it will fix a leak if there is one.
My 2.2cl is also blowing hot air but could I just try and use this "stop-leak" product and then add the R134a to see if it works? I think I can hear the cluth plate engauging so I'm pretty sure that is okay. Will I hurt my A/C system by just trying this cheaper and inexpensive procedure?
Also, to use this procedure would I use the little blue cap with the "L" on it a few inches back from the rad (1997 2.2cl)? there are 2 blue caps coming off the same rod?
Thanks for the help!
Old 07-12-2008 | 08:23 PM
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
On my Landcruiser I had sporadic loss of cooling. I wasted 50.00 on one of the kits before I took it to a shop and it was the expansion valve. it was 300.00 to fix but that was almost two years ago and it is still fine.
tsx_boy
12-13-2019 09:33 PM
Biggie_B
02-26-2017 12:14 PM
detailersdomain
Wash & Wax
10-09-2015 11:13 PM
Kres43
1G RDX (2007-2012)
10-03-2015 08:16 PM
hashbrown
09-29-2015 01:13 PM
