Belt to bypass AC
Old Sep 9, 2009 | 09:02 AM
khmerpride's Avatar
Belt to bypass AC
I just bought my car and the last alternator belt fell off a little bit at the a/c compressor pulley and it ripped to pieces. I put on a new belt last night thinking the mechanic did a mistake and it did the same thing after 2min. I could see the belt and pulley moving back and forth on the pulley so I'm guessing the bearing is bad. I already checked the noob posting but I just want a second opinion on this. If I were to order a belt for a honda 94-97 accord with no a/c, would it fit on my acura 2.2 cl if I were to put it on the alternator and the crank pulley which bypasses the a/c? That's the idea anyways, my a/c doesn't work so I would just like to bypass it, do you think it'll fit?
Old Sep 9, 2009 | 12:40 PM
WineRed2.2CL's Avatar
Old School Ridin Clean
lol.....man you are going no where doing things that way
Old Sep 9, 2009 | 01:27 PM
khmerpride's Avatar
Well my a/c system is too expensive for me to repair so I just want to bypass the ac compressor. Will a serpentine belt from an 94-97 accord with no ac fit on my 2.2? Apparently it says they are both f22b1 engine.
Old Sep 9, 2009 | 03:00 PM
YtseJammer's Avatar
Low and Slow
I took my a/c compressor out and measured the distance from the bottom pulley to the alternator, although I can't remember the exact distance. Went to pepboys and bought a couple belts for like $20 and put them on. Car has ran just fine since.
Old Sep 9, 2009 | 10:11 PM
khmerpride's Avatar
problem solved, belt from an 94-97 accord with f22b1 did fit
tsx_boy
Dec 13, 2019 08:33 PM
08KBP_VA
Oct 22, 2019 01:55 PM
Jboat
Sep 30, 2015 10:58 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
