bad rear main seal
Old Oct 9, 2006 | 10:09 AM
jumpmanbsktbll's Avatar
2.4 L iVtec
bad rear main seal
thats where my oil leak is coming from
he said about 8-900 since he has to take out the tranny
anyone else ever have this problem
he said i dont need it bad since it isnt leaking too bad
Old Oct 9, 2006 | 08:56 PM
subbuzz's Avatar
07 tl-s in
one of my many probs.tranny does have to come out,it sucks.................
Old Oct 9, 2006 | 09:02 PM
TexasHonda's Avatar
Locating an oil leak is very difficult and easy to misjudge the source of the leak. While a main crank seal could leak, there are very few reports of this and lots of reports of VTEC solenoid valve leaks, valve cover leaks, rear balance shaft/oil pump cover leak, low oil pressure switch leaks, and distributor shaft oring leaks. I would make sure it's not one of these sources before undertaking a rear main seal replacement. It would be terribly disappointing to perform such a repair and find the leak source was elsewhere and still present!
Cleaning engine and using a UV dye can assist in tracing the path of a leak.
good luck
Old Oct 9, 2006 | 09:29 PM
2.4 L iVtec
good luck
Yeah but Id hate to keep paying money to have it looked at...had to pay the dam dude 83$
i think its time to ditch it and pick up a lude
Old Oct 9, 2006 | 10:33 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
I had mine out for the main seal down the center of the tranny. $600+ to replace a freakin gasket
Old Oct 9, 2006 | 10:40 PM
danielsmi's Avatar
Yep I also had a rear main seal leak, and it was bad that was just a couple months ago.
Old Oct 11, 2006 | 09:24 PM
732xghost's Avatar
good luck
i would like to add that your very knowledgable. thank you for that, so do you have a CL.
Old Oct 11, 2006 | 11:00 PM
danielsmi's Avatar
I think there would be some sort of refund or warranty if they thought it was the rear main seal and it ends up it wasn't. Now that I think of it , it seems it would be hard to mistake the rear main seal for anything else since I believe that is the lowest point that the oil can exit from since it's all the way at the bottom where the engine connects with the tranny. So if there was oil residue above the rear main seal then it couldn't be that. I think most shops would do I good enough job of looking for an oil leak before telling the customer it's gonna be $750 to fix an oil leak, unless you went to a shady one but even then if you spend that much and your car is still leaking then there's got to be a warranty or something.
Old Oct 12, 2006 | 05:52 AM
TexasHonda's Avatar
My daughter is driving and I'm maintaining a 97 2.2 CL.
regards
Old Oct 12, 2006 | 09:09 AM
732xghost's Avatar
im sure with you around that car is in great shape. sounds like you were a mechanic at one time or another.
Old Nov 4, 2006 | 05:10 PM
UcMeInThat2.3's Avatar
hi im new to this forum an jus wanted to say i've had the same problem an it destroyed my clutch....but me an my neighbor switched it out in about two hours but i still need a new trans...
Old Nov 4, 2006 | 06:57 PM
Chemmech's Avatar
If ur in So Cal, I'll change it for $500 .
Old Nov 5, 2006 | 01:28 PM
732xghost's Avatar
hes from south jersey...
Old Apr 8, 2008 | 10:54 AM
stevebri's Avatar
138,000 Acura 99 cl 3.0
I may have the same problem, but I am not sure, my mechanic also has to replace the oil pan and this may be the problem. He also says I have a leak in the power steering high pressure line. I have to say, if I didn't have debt to pay off I'd unload this thing and get a new car (definitely not Acura or Honda). As of right now, I'm almost done with my car loan and I wanted to pay off some debt.
Old Apr 8, 2008 | 06:53 PM
swiftt5389's Avatar
Acura/Honda 's FTW
Old Apr 8, 2008 | 07:17 PM
AznX TL's Avatar
where is....
i had a leak on the power steering high pressure line, and its a pain to change, and the hose itself is $130.
Old Apr 10, 2008 | 07:15 PM
TexasHonda's Avatar
Yes, my daughter drives a 2.2CL which I maintain. I also drive a 94 Accord EX, basically same mechanically. Previously I owned a 90 Accord EX that I bought at 190K and drive to 270K. Love those 2.2L engines.
regards
Feb 25, 2020 09:57 AM
yesSIR-S
May 13, 2016 05:42 PM
IIDXholic
Oct 8, 2015 07:53 AM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
Sep 4, 2015 08:03 AM
