Another ABS Thread - Where to Find Code Meanings?
Old Nov 6, 2014 | 07:41 PM
UWMU's Avatar
1998 2.3CL
My ABS light has been on for awhile and I'm hoping to fix it. I've replaced a few wheel sensors in the past with the help of these forums.
I've spent about 45 minutes looking at old threads to see if I can find the list of ABS codes for 1998 models, and can't find it. Some of the threads link to websites that are now dead.
Anyone remember where this list of code meanings is? I'm pulling these codes:
1-5
1-6
1-7
8-1
Thanks!
Old Nov 6, 2014 | 07:55 PM
UWMU's Avatar
1998 2.3CL
Found:
DTC Code Lookup
No DTC and ABS Indicator OFF: ABS indicator does not come on.
No DTC and ABS Indicator ON: ABS indicator does not go on (no DTC).
DTC ON for rest
1-1 Wheel sensor Front Right (open/short to body ground/short to power)
1-2 Wheel sensor Front Right (electrical noise/intermittent interruption)
1-3 Wheel sensor Front Left (open/short to body ground/short to power)
1-4 Wheel sensor Front Left (electrical noise/intermittent interruption)
1-5 Wheel sensor Rear Right (open/short to body ground/short to power)
1-6 Wheel sensor Rear Right (electrical noise/intermittent interruption)
1-7 Wheel sensor Rear Left (open/short to body ground/short to power)
1-8 Wheel sensor Rear Left (electrical noise/intermittent interruption)
2-1 Pulser Front Right
2-2 Pulser Front Right
2-3 Pulser Rear Left
2-4 Pulser Rear Left
3-1 Solenoid Front Right-IN (short to body ground/short to wire)
3-2 Solenoid Front Right-OUT (short to body ground/short to wire)
3-3 Solenoid Front Left-IN (short to body ground/short to wire)
3-4 Solenoid Front Left-OUT (short to body ground/short to wire)
3-5 Solenoid Rear Right-IN (short to body ground/short to wire)
3-6 Solenoid Rear Right-OUT (short to body ground/short to wire)
3-7 Solenoid Rear Left-IN (short to body ground/short to wire)
3-8 Solenoid Rear Left-OUT (short to body ground/short to wire)
4-1 Wheel Lock Front Right
4-2 Wheel Lock Right
4-3 Wheel Lock Left
4-4 Wheel Lock Left
5-1 Motor lock
5-2 Motor stuck OFF
5-3 Motor stuck ON
5-4 Fail-safe relay
6-1 Ignition voltage
6-2 Ignition voltage
7-1 Different diameter tire
8-1 Central Processing Unit (CPU) diagnosis, and ROM/RAM diagnosis
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
