Another ABS light problem.
Hi, I have a '97 CL 2.2 with the abs light on. Occasional the petal goes soft but still brakes.
I've read a bunch of other posts with the same problem but I haven't seen the code I get.
As per instructions in the other posts I get:
****____******** Repeating
48 I assume. Could any kind person tell me what the code translates to? Is there a list somewhere? I couldn't find one searching.
Thanks for your time.
my work van used to come on when ever it liked. it would be winter, -30, and id slam on the brakes and no abs,.. it would be summer, +30, my shoe lace would fall on the pedal abd the abs kicked in n shit,... pppffff, fuckn hate abs.
Dry, both hot ~100f and cooler ~60f. Lights been coming on for a week or so now. Occasional vibrating noise when I crank the car just not every time. Every 10th or so. But the light stays on just the same. The pedal isn't soft all the time just a couple 3 times now. Still stops, just at the bottom of the pedal.
Checked both fluid reservoirs. Both are full to right above the full line.
Any ideas? -Thanks
Any ideas? -Thanks
i had the pump issue and was told buy acura that it is an o-ring in the bottom of the pump that is the issue.,. i never really pursued it further as i hate abs and want it gone. i dont know enough about the speed sensors to give an accurate assessment but they seem like they would fail because of the location of them and when sensors go bad it can be intermittent, kinda like you speak of.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
