AC problems
Old Jul 9, 2009 | 08:38 PM
shnee's Avatar
Land of Pleasant Living
AC problems
Haven't had AC for a while.
When I turn it on, it shoots little bits of debris (like dirt or something) at me. I tried using a recharge kit, but it did nothing. The pressure would keep rising and then fall completely.
With the debris and pressure problems, I assumed there was a big leak or hole somewhere. But I traced the lines as best as I could and found no obvious issues.
Where else can I look besides the hoses?
Any idea what it might cost to get the issue resolved, whatever that may be?
Old Jul 9, 2009 | 11:21 PM
WineRed2.2CL's Avatar
Old School Ridin Clean
around 400
Old Jul 10, 2009 | 07:06 PM
TexasHonda's Avatar
First step is to determine if the system is holding refrigerant. If you have a gauge test system pressure at low side access port. Pressure should be roughly equal to air temperature in degF (100F = 100 psia) w/ cold engine.
If you have decent pressure, this doesn't mean you don't have a leak, but since system has not been running for some time, it says the leak is very small or perhaps no leak.
If you have no pressure, there's a leak that must be repaired before charging. Finding a leak can be simple or complex. Look at all the connections and hose crimps for evidence of dirt/oil accumulation.
Look around compressor clutch plane for evidence of oil (oily/dirty ring) thrown out from clutch plate. This indicates the compressor seal is leaking.
Check condensor face for yes, oil/dirt accumulation indicating a leak.
If everthing under the hood looks good, that means the evaporator may be the source of the leak. Not a difficult job to pull the evaporator. Usual problem is leaking orings on expansion valve and thermal feedback bulb. New orings lubed w/ Nylog and evap should be good. Clean thoroughly when removed.
Flush condensor, drain compressor, and replace receiver-drier. Add 7-8 oz of double-end capped PAG for lube, close system, vacuum for 5 mins, and isolate gauge valves. If system holds vacuum (no/small drop after 15 mins w/ gauge valves closed), then continue vacuuming for at least 30 mins - 1hr to completely dry system. Charge spec amount of R134a (23 oz?) into low side, and enjoy the cool.
You may want to remove your blower and check for dirt/leaves in blower box. Easy removal.
good luck
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
