ABS light turns on after 70MPH
Old Jun 1, 2007 | 01:15 AM
RussianPride24's Avatar
wanna buy my car?
So every time I hit 70mph my ABS light comes out and the ABS gives out until the next time I start the car. I really don't know why it does that and I'm wondering if any of you guys know the problems.
The reserve tank for the brake fluid had a crack in it on the top and some fluid would leak out. I got that fixed and added the brake fluid to match the level. Still the light comes on after 70.
Any ideas why it does that?
and here's a crappy cellphone pic with the light on.
Old Jun 1, 2007 | 07:30 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
That my friend is a bad wheel speed sensor, trust me i've replaced 3 already
Old Jun 1, 2007 | 09:30 AM
TiggerCarman's Avatar
My ABS lights fail at 85MPH, and now I drive below 85. So, I haven't get my problem fix yet....
Old Jun 1, 2007 | 05:46 PM
Nakamichi's Avatar
~[ô¿ô]~
Try getting the ABS Diagnostic Trouble Code (DTC), it could probably point you in the right direction. Or someone may be able to get you the troubleshooting steps.
How to get ABS Diagnostic Trouble Code (DTC)
1. Use a paper clip is similar conductive device to complete the circuit for the service check connector located on passenger's side under the dash.
Same shape as this, except on passenger side and blue
2. Turn the ignition switch ON (II) without the brake pedal depressed.
3. The blinking ABS light frequency indicates the DTC.
NOTE: If the DTC is not memorized, the ABS indicator will go off for 3.6 seconds, and then come back on.
4. Turn the ignition switch OFF, and remove the paper clip.
Conditions for DTC indication
  • Vechicle speed is 6 mph (10 km/h) or less.
  • The paper clip is connected before the ignition switch is turned ON (II).
  • The brake pedal is released.
How to read DTC
For example a DTC of 4-2, will have 4 slow blinks then 2 fast blinks.
There is a 0.5-second pause between the slow and fast blinks and 3.6-second pause between each DTC. The ABS system can hold multiple DTCs. So supposed you had 3 DTC of 2-1, 1-2, 1-1; Your ABS light will react as the following:
Ignition ON (II)
- Bulb check (2 seconds)
- 3.6 sec pause
DTC 2-1
- 2 slow blinks
- 0.5 sec pause
- 1 fast blink
- 3.6 sec pause
DTC 1-2
- 1 slow blinks
- 0.5 sec pause
- 2 fast blink
- 3.6 sec pause
DTC 1-1
- 1 slow blinks
- 0.5 sec pause
- 1 fast blink
- 3.6 sec pause
DTC Code Lookup
No DTC and ABS Indicator OFF: ABS indicator does not come on.
No DTC and ABS Indicator ON: ABS indicator does not go on (no DTC).
DTC ON for rest
1-1 Wheel sensor Front Right (open/short to body ground/short to power)
1-2 Wheel sensor Front Right (electrical noise/intermittent interruption)
1-3 Wheel sensor Front Left (open/short to body ground/short to power)
1-4 Wheel sensor Front Left (electrical noise/intermittent interruption)
1-5 Wheel sensor Rear Right (open/short to body ground/short to power)
1-6 Wheel sensor Rear Right (electrical noise/intermittent interruption)
1-7 Wheel sensor Rear Left (open/short to body ground/short to power)
1-8 Wheel sensor Rear Left (electrical noise/intermittent interruption)
2-1 Pulser Front Right
2-2 Pulser Front Right
2-3 Pulser Rear Left
2-4 Pulser Rear Left
3-1 Solenoid Front Right-IN (short to body ground/short to wire)
3-2 Solenoid Front Right-OUT (short to body ground/short to wire)
3-3 Solenoid Front Left-IN (short to body ground/short to wire)
3-4 Solenoid Front Left-OUT (short to body ground/short to wire)
3-5 Solenoid Rear Right-IN (short to body ground/short to wire)
3-6 Solenoid Rear Right-OUT (short to body ground/short to wire)
3-7 Solenoid Rear Left-IN (short to body ground/short to wire)
3-8 Solenoid Rear Left-OUT (short to body ground/short to wire)
4-1 Wheel Lock Front Right
4-2 Wheel Lock Right
4-3 Wheel Lock Left
4-4 Wheel Lock Left
5-1 Motor lock
5-2 Motor stuck OFF
5-3 Motor stuck ON
5-4 Fail-safe relay
6-1 Ignition voltage
6-2 Ignition voltage
7-1 Different diameter tire
8-1 Central Processing Unit (CPU) diagnosis, and ROM/RAM diagnosis
Old Jun 2, 2007 | 10:31 AM
starboy2nv's Avatar
First EVER K24 Turbo CL
i think thats your boost indicator
Old Jun 2, 2007 | 10:39 AM
saiko_cl_duck's Avatar
hmmmm, that finger looks verrrry familiar...........
Old Jun 21, 2007 | 09:42 AM
RyeCL's Avatar
my light was doing the same thing. i had the speed sensor replaced twice. it ended up being the axle. something with a notch on the axle and when it spun fast it tripped the sensor. so replaced axle and all was good again.
Old Nov 28, 2009 | 12:59 PM
UWMU's Avatar
1998 2.3CL
Sorry to resurrect such an old thread, but do the codes in Nakamichi's post apply to 1998 CLs? I thought I saw somewhere that the codes are different for 97 and 98-99s, but I just wanted to make sure.
I'm getting a 1-5 ABS code on my 1998 2.3CL, the right rear ABS wheel sensor code. I cleaned off the corrosion and inspected the wire and the code didn't go away. Anyway, just wanted to make sure this is the right code so I'm going down the right path before buying a part I might not actually need.
Old Nov 29, 2009 | 12:33 PM
TexasHonda's Avatar
See following link for 98 2.3CL at autozone. 15 = Front Right wheel sensor. I would clean the sensor face and also the tone ring. Stuff a rag in the hole tightly against the tone rig and rotate the wheel to polish the lugs. If this doesn't work check resistance of sensor. I don't know your spec and didn't see it at autozone, but is usually 500-1000 ohms. If short or open, the wheel sensor is bad.
http://www.autozone.com/autozone/rep...00c1528008c0b8
good luck
Old Nov 30, 2009 | 06:18 PM
UWMU's Avatar
1998 2.3CL
Thank you TexasHonda! I'm glad I checked with you before unnecessarily buying the RR sensor.
Old Nov 30, 2009 | 07:41 PM
TexasHonda's Avatar
If you need a wheel sensor check ebay for used units; < $50.
good luck
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
PortlandRL
Sep 14, 2015 12:01 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
