ABS light
Old Feb 13, 2006 | 12:19 AM
ninjaturtle420's Avatar
ABS light
sup everyone,
a little while ago my breakes got messed up(pulsing, sqeaking, etc....) anyway, i replaced them and they work perfectly now but the problem is that my ABS light still comes on. if i reset my car will that messup my new head unit?
thanks
Old Feb 13, 2006 | 03:48 AM
saiko_cl_duck's Avatar
it wont mess it up if you disconnected the positive terminal on your battery. If you have a unit with a code, make sure you know what it is.
your light should reset, if it doesnt, get it checked out.
Old Feb 13, 2006 | 11:52 AM
Palayah8ta's Avatar
Ciao Pho Eva eva
The abs light on my car comes on after driving my car for like 20+ mins. But it doesnt come on next time u start my car. Wtf is up with my car?
Old Feb 13, 2006 | 12:35 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Wheel speed sensor, I've already replaced 3 of them
Old Feb 13, 2006 | 10:10 PM
teh CL's Avatar
try topping off ur brake fluid..
Old Feb 14, 2006 | 12:52 AM
Palayah8ta's Avatar
Ciao Pho Eva eva
i did it, didnt help.. lame
Old Feb 14, 2006 | 03:08 AM
thanks alot
Old Feb 14, 2006 | 08:14 AM
teh CL's Avatar
worked for me
Old Feb 14, 2006 | 10:49 AM
(Mid-Atlantic)
bump
Old Feb 24, 2006 | 01:30 PM
Zidor's Avatar
Just out of curiousity do you guy even check your WSS before you replace them? All i see and hear is 'abs light replaced 7 wheel sensors' just cause your ODBII sends a WSS code doesn't mean it is physically defective if the Hall effect wheel is broken or what not you will throw the same code, if your rolling wheel diameter changes *i stree this one caues people put larger rims on and don't try and match the stock size* it will do the same thing
Old Feb 24, 2006 | 04:34 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
1st off where da fuk is ur WSS, and 2ndly how spensive are we talking? gracias..
Old Feb 25, 2006 | 10:35 PM
Zidor's Avatar
WSS= Wheel Speed Sensor, they are located on the other side of your rotors either externally or interally to the Spindel
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Stu2414
Aug 30, 2015 07:30 PM
