ABS light
ABS light
sup everyone,
a little while ago my breakes got messed up(pulsing, sqeaking, etc....) anyway, i replaced them and they work perfectly now but the problem is that my ABS light still comes on. if i reset my car will that messup my new head unit?
thanks
thanks
it wont mess it up if you disconnected the positive terminal on your battery. If you have a unit with a code, make sure you know what it is.
your light should reset, if it doesnt, get it checked out.
Originally Posted by Palayah8ta
The abs light on my car comes on after driving my car for like 20+ mins. But it doesnt come on next time u start my car. Wtf is up with my car?
Just out of curiousity do you guy even check your WSS before you replace them? All i see and hear is 'abs light replaced 7 wheel sensors' just cause your ODBII sends a WSS code doesn't mean it is physically defective if the Hall effect wheel is broken or what not you will throw the same code, if your rolling wheel diameter changes *i stree this one caues people put larger rims on and don't try and match the stock size* it will do the same thing
mada51589
Jan 9, 2025 04:40 PM
