98 CL 3.0 No Crank
Old Nov 1, 2011 | 05:10 PM
jbrier87's Avatar
Angry 98 CL 3.0 No Crank
Hey guys, I've been working on my 98 CL 3.0 for two days now and have not made much progress. It all started when my serpentine belt broke, I noticed my alternator was harder to turn than it should be so I replaced it with a remfd unit. After replacing the alternator I have a no crank problem. I've checked voltages at every fuse and relay in the vehicle, I have battery voltage at the starter and battery voltage at the S terminal when the key is in the start position, which leads me to believe the ignition switch is ok. Starter bench tests fine, works everytime. I tried to scan codes with the Snap-On Modis I've got and it will not communicate with any module in the vehicle. Also, with the key on, the speedo will shoot up to 80-120 mph and jump around if you play with the gas pedal, while it's doing this it is clocking miles on my trip and odometer. If anyone has a suggestion please shoot them my way, I'm stumped.
Old Nov 8, 2011 | 08:35 PM
cjleveille's Avatar
This is just a guess, but a computer problem could be an issue if it won't communicate with your Snap on modis. I am sure that has a lot to do with the car running correctly. Search the forum for computer problems and see what you come up with.
acuratl26
Apr 23, 2020 07:30 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
Mikehxbx
Aug 31, 2015 10:17 PM
