98 2.3 CL Crank but won't start!
Old May 29, 2011 | 03:51 PM
eusadnama's Avatar
3rd Gear
Hi,
I am new to the forum and I have a major issue with my 98 2.3 CL.
My husband and I drove our CL to Louisiana for Memorial Day weekend. Before we left we had the oil changed and had it looked over to be sure we'd be good on the drive there from our home outside Little Rock, AR. It drove fine, no issues. We got to Louisiana, parked it and got back in it and it was fine.
We parked and drove it about 5 more times, and it increasingly sputtered and gave us trouble starting. It also eventually started emitting white smoke out of the transmission while doing so. But after about 2 minutes of running it would run smooth and quit smoking. It also drove fine, no overheating no rough idle. It finally would not start again AT ALL and is now broken down in Louisiana.
I would also mention that it had been seeming hesitant to crank before this, but my battery terminals are in terrible shape so we assumed that was the issue. Obviously not. We checked the fuel pump and it was fine. So what else could we be dealing with here?
Sorry this was long-winded. Wanted to get in all the facts.
Old May 29, 2011 | 04:07 PM
eusadnama's Avatar
3rd Gear
Oh goodness, it has been a long weekend, out of the EXHAUST not the TRANSMISSION is where the white smoke was coming from.
Old May 29, 2011 | 05:05 PM
97'CL2.2's Avatar
white smoke usually means coolant in the combustion chamber...where it isnt supposto be. check your coolant level. if its low id consider a head gasket may have blown, you can confirm this by doing a compression check.
Old May 29, 2011 | 07:45 PM
eusadnama's Avatar
3rd Gear
I had a feeling it may be the head gasket. But I was also told it may have jumped time or the crank position censor may have gone out. But both of those things do not seem to match the symptoms the car is showing.
Old Jun 11, 2011 | 08:35 PM
2door's Avatar
another vote...head gasket
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
